E85 mix
07-13-2015, 10:01 AM | #1 |
18
Rep 187
E85 mix
GM guys, usually when I run e85 it's 2 gallons and half a tank 93.... Some times I get 17.5psi but if my fuel pumps are factory, how much e85 can I safely run.
07-13-2015, 10:09 AM | #4 | ||
57
Rep 272
FBO , MHD , tuned
07-13-2015, 10:10 AM | #5 |
2134
Rep 3,554
07-13-2015, 10:27 AM | #8 |
3441
Rep 79,211
07-13-2015, 10:32 AM | #9 |
261
Rep 1,093
Approx 4 gallons of E85 with the rest (12 Gallons) pump gas (E10) will give you E30. 6 gallons of E85 will give you E40. If your gas is straight petrol (no ethanol) you will fill with 6 gallons of ethanol and 10 gallons of straight petrol for E30 and a 50/50% mix for E40 (8 gallons E85 + 8 gallons of Petrol). These are based on E85 figures. Your E85 pump may be anywhere from E70-E90.
07-13-2015, 10:34 AM | #10 | |
18
Rep 187
07-13-2015, 01:17 PM | #11 |
Rep 18
This mixture can be greatly off of the e85 your using has poor quality.. I say test before u mix..
Example your mix calculators is based off of 85% ethanol content where as some places can have 78% when tested if that makes sense |
07-13-2015, 02:56 PM | #12 | |
Guest
Rep n/a
Drives:
OP: what tuning solution are you using? |
07-13-2015, 03:15 PM | #13 |
533
Rep 2,872
Log often, review the logs, and that will determine how much E85 you can run on the stock LPFP. My car ran best on E35-40, some can't run more than E20-25, some can run E45.
07-13-2015, 04:04 PM | #14 |
BimmerPost Supporting Vendor
24273
Rep 190,975
+1 make sure to log often and double check that your fuel pumps are good.
07-13-2015, 07:16 PM | #15 | |
184
Rep 1,702
Drives: Audi TTRS, 335is
Can't stress this enough. Log! My friends LPFP died with E25 (105k on car/pump). Every pump is different. Start low, log, and increase accordingly. |
