please help anyone? searched forums for some of these problems and got nothing
07-13-2015, 06:29 AM | #1 |
Rep 7
please forgive me if ivve posted in the wrong section
so its been about 10 months since owning my e92 320d with 53k on the clock. everything was fine until problems started happening 3 months ago got the yellow handbrake light with the triangle and exclamation mark in it on dash. when i go to check engine via the control stick i get tyre pressure light break light and dtc light. ive been reading somewhere that it could either be wheel speed sensors steering sensors ? my bloody code reader dosent seem to want to read the chassis option keeps saying no communication however when i check (driver) i come up with a few codes i dont really understand. first of all is A126 implausible signal from engine management - never got this before any help ? 2E41 HFPI control module line 5 activation ???? 480a paticualte filter - which i understand is common to occur in diesels 4D00 exhaust back pressure sensor signal - againsame as the above any help on these issues? also to add since i bought the car occasionally there would be a lagre cloud of black smoke that comes from the exhaust so big that it makes my silver bumper really dirty, my insurance is due for renewal in octorber should i just sell the car then and buy something else ? please any help is greatly appreciated |
07-13-2015, 11:50 AM | #2 | |
Curmudgeon and Pedant
690
Rep 3,489
1) You have some sort of problem with your abs/dsc system. As you know, wheel speed sensors, steering wheel angle sensor, or perhaps the pump or distribution block are at fault. I think you're going to have to pay someone with a real BMW code reader (GT1, AutoLogic, or 2nd rank like Bavarian Technic) to read the codes to figure out exactly what. 2) You may well have a failing exhaust pressure sensor. It is pretty common for the line to fray/melt/leak. Let's hope you don't have a plugged DPF/Catalyst as that's a pricey replacement. If you're typically a city driver (and you are if you're anywhere near London!), go out and drive the M1 up north a couple hundred miles, then back. That should allow a DPF regeneration to happen and clear any DPF clog. If that doesn't fix it, the pressure sensor or DPF itself is indicated as next to check. |
