07-10-2015, 08:00 PM | #1 |
432
Rep 887
Drives: Enzo F23 228i
Coding Offline ?
Do most of you code offline so you don't have to sit there with the engine running?
Also, do most of you make multiple changes at one time, assuming that you are tracking what you have changed? |
07-10-2015, 09:33 PM | #2 | |
1398
Rep 5,262
Open Esys - Start the car - Connect - Read coding data - disconnect - shut off the car - Make all the changes offline - start the car - connect - activate FA - Code FDL - disconnect - shut off the car - Close Esys make sure you don't close esys in the process so that you don't have to browse each saved .ncd individually as you could end up loading the HU_NBT into the KOMBI for example... It's less time consuming to do all at once to reduce time of engine running |
07-10-2015, 10:32 PM | #3 | |
432
Rep 887
Thanks |
07-10-2015, 10:43 PM | #4 | |
1398
Rep 5,262
07-10-2015, 10:54 PM | #5 | |
432
Rep 887
I also looked at the HU_NBT. First thin I looked at was the DVD in Motion. I have no listing for your SPEEDLOCK_X_KMH_MIN/MAX values. The others I could find. I'm taking a break now to give my eyes a rest. |
07-10-2015, 11:04 PM | #6 | |
1398
Rep 5,262
where it says Search for: just put the term there and it will take you right there. Make sure you don't add spaces i.e. "SPEEDLOCK_X_KMH_MIN" will work "SPEEDLOCK_X_" will work "SPEEDLOCK_X_KMH_MIN " will not give any results |
07-10-2015, 11:40 PM | #7 | |
432
Rep 887
I just realized that I have the HU_NBT2...might explain some things. Last edited by OpenAir; 07-11-2015 at 12:13 AM.. |
07-11-2015, 10:32 AM | #8 | |
1398
Rep 5,262
07-11-2015, 11:38 AM | #9 |
432
Rep 887
07-11-2015, 11:43 AM | #10 |
432
Rep 887
Most things worked, but the HU_NBT2 threw errors. Even when I tried to load the oem ncd back into the system, it still threw errors.
I'm starting to think this version of E-Sys has issues with the latest ECU's. Now I want to flash everything back to stock (some way to reset everything) and start out slow. I will say I did the vision hack and now both of my headlights point to the left and don't come back after you reach 30mph as suggested...just keeps looking left. If I make a right turn they swing from left to right and then back to left...make you dizzy. I was playing with this at 3AM this morning...long night. So how do I reset the system? |
07-11-2015, 01:13 PM | #11 | |
1398
Rep 5,262
http://www.bimmerfest.com/forums/sho...d.php?t=843950 Yes resetting to factory is really easy.... Just select the ECU you want to reset (i.e. HU_NBT2) and click "CODE" instead of CODE FDL.... BY NO REASON EVER CLICK "CODE DEFAULT VALUES" Also make sure you don't code the whole ECU tree as you will be coding the DME module with the engine running and the car will shut off and throw errors |
07-11-2015, 07:16 PM | #12 | |
432
Rep 887
07-11-2015, 10:37 PM | #13 |
432
Rep 887
Just flashed everything back to OEM and all my changes have been corrected. Funny thing, I could code the HU_NBT2 without an issue, just can't do FDL coding.
Anyway, thanks for all the help shawnsheridan and pikcachu! |
07-11-2015, 10:42 PM | #14 |
1398
Rep 5,262
