Misfire Coming Back To Haunt Me!
07-10-2015, 05:07 PM | #1 |
Live life to the fullest!
12
Rep 175
Hey guys so in my previous post I had a misfire on cylinder #2 and after everything it ended up being dielectric grease on the connector to the coil. Everything was cleaned out on everything and recently there was a misfire on cylinder #3. New injectors, spark plugs and coils. Only around 500km on the car after all this. I swapped coils, plugs and still misfire on cylinder #3 under load. It is driving me crazy and now we have a huge event this weekend for Street Wheelers. Cars from everywhere come to this. Any help would be fantastic guys. Cheers.
FBO - CPE DP'S, CUSTOM CXRACING FMIC, STETT CAI, KW'S, COBB V3, WEDGE PRO TUNE, ALPINA B3 FLASH
07-11-2015, 12:31 AM | #2 | |
352
Rep 2,050
Try logging it maybe he injectors are dying out
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
07-11-2015, 01:40 AM | #3 |
12
Rep 175
Hey man valve cover gasket was replaced around 1000km ago. And the injectors are like brand new, all 6 of them to the newest version. They are coded as well. My car ran good for awhile then there was issues.
07-11-2015, 02:22 PM | #7 |
12
Rep 175
Would that cause a single cylinder misfire? LPFP and HPFP looked good last time Buraq check my logs. I'll prob go and log again now.
07-11-2015, 03:24 PM | #8 |
12
Rep 175
So I just changed my tune back to stock. Took it for a drive and now I'm getting a misfire on cylinder 6!?
07-11-2015, 04:14 PM | #10 |
12
Rep 175
I've changed my plugs a few times. Misfire cylinder 6 on stock mode and cylinder 3 on protune 94 and e40. It only happens under hard acceleration usually between 3-6. New plugs, coils, injectors(coded) and VCG.
07-12-2015, 05:41 AM | #11 |
469
Rep 1,538
I believe that it's possible to have a failed transistor on the MSD80 ECU. There is 1 transistor per injector which acts as an amplifier from the ECU to the injector.
There was a good DIY somewhere from Roy Cormier. I think Wedge knows a guy who can fix it for a small fee if you aren't kitted up to solder a new transistor on. Not sure how to diagnose a failed transistor other than open up the ECU and get a multimeter in there. If the misfire was just in 1 bank then it could be the O2 sensor but you said it happens in cyl3 and 6. Run a log that has low and high pressure fuel values monitored and post it here. Another thing to check is the injector installation. take the engine cover off and check that the decoupler is fitted to each injector and that the metal tabs are still attached. A few guys including me have had dealerships forget decoupler and snap the metal tabs off injectors which leads to the injector moving around in the cylinder and knocking the spray pattern out. |
07-12-2015, 12:56 PM | #12 | |
12
Rep 175
http://www.datazap.me/u/cbmac7/misfi...-9-10-11-12-15
07-12-2015, 02:32 PM | #13 |
12
Rep 175
When I started my car this morning before my log checked for any codes. These codes popped up now.
P29CF P29D1 P29D2 P29CC I ran my log and the codes were cylinder 3 and cylinder 6 misfire.
07-12-2015, 02:34 PM | #14 | |
469
Rep 1,538
You can see my bank 1 and bank 2 afr are following eachother quite tight. Yours seem to be drifting apart. If you check your short term fuel trims it looks like they are working hard to try keep things in check. Also if you look at the high pressure fuel on your chart it drops pretty sharply midway through the pull whereas mine is sticking to 2000~. Read this awesome post from PTF. It should give you an idea of what to look for in the way of fuel in the logs. (http://www.e90post.com/forums/showthread.php?t=1120250) I don't fully know how the fuelling system operates so I couldn't tell you if your HPFP is on the way out or not. It looks like it's dropping way below the minimum of 1500 that PTF recommend but maybe it's programmed to do that when it sees that it's running really rich in bank 2. Could even be a dud O2 sensor giving false readings. I would ask a tuner like Wedge/BQ or PTF. They might be able to instantly tell you what's wrong as they deal with these issues regularly. |
07-12-2015, 02:49 PM | #15 | |
12
Rep 175
07-12-2015, 03:00 PM | #16 | |
469
Rep 1,538
I just read your sig and since you already have a Wedge tune I'm sure he would be keen to help out. |
07-13-2015, 07:00 PM | #17 |
12
Rep 175
My DME is actually MSD81. I just pulled it out to open it to check transistors. I thought it was MSD80 for the longest time.
07-13-2015, 08:24 PM | #18 |
469
Rep 4,392
Previous log last month after everything was squared away with the dealer shows a perfectly healthy running and performing car
http://datazap.me/u/cbmac7/bqe40-rl-...7-18-20&solo=9 Most recent log you HPFP is falling on its face which was doing that before http://datazap.me/u/cbmac7/misfire-c...-3-9-15&solo=9 Ive seen countless car's HPFP drop below 1000 PSI and never throw a misfire. It definitely something fueling related. the trims don't make sense of failing HPFP though. |
07-13-2015, 09:39 PM | #19 |
469
Rep 4,392
I see why your misfiring now in that last log. AFR's are going too rich especially on E40-E45 fuel. The DME is trying to achieve AFR target but it just keeps going rich. So the DME pulls trims and reduces fuel pressure, but fuel keeps going rich which is causing your misfire.
You should be smelling a lot of fuel. Bank 2 looks like where its dumping the most fuel. Something is failing mainly in bank 2 . The other crazy part is after the misfire fuel was kept on being dumped in bank 1 after bank 2 leaned out You got to be smelling a lot of fuel. Back to checking injectors, plugs and coils. |
07-14-2015, 07:03 AM | #20 | |
469
Rep 1,538
07-14-2015, 07:44 AM | #21 |
469
Rep 4,392
07-14-2015, 02:26 PM | #22 |
12
Rep 175
I haven't really noticed the smell of fuel guys. My thoughts were o2 sensor as well but now that you say HPFP I wonder what it really is. It's booked to go back into the shop on Monday. I reset all adapations and had my DME out of the car because I thought it was a MSD80 but its a MSD81. Battery was also reset. Now my car as an error light "Lightining System! Stop vehcile" Any help on this would help also.
