2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes SUPREME POWER l Bilstein PSS10 (M235 & 228i)
      07-08-2015, 03:33 PM   #1
supremepower
Supreme Leader
supremepower's Avatar
Drives: G80, 996GT2, 996TT, 991RS 356b
SUPREMEPOWER
1025-B Ortega Way
Placentia CA 92870
(714)632-1951
sales@supremepower.com
Bilstein
Bilstein's best and hottest suspension setup is now available for the F22 2 series coupe. This system features 10-way adjustable dampeners/shocks and front and rear ride height adjustment. This is one of our favorite "trackable" street suspension setups, great for any 2 series (228i and M235i) BMW. On the softest settings, it's compliant enough for typical city and highway driving, and on the firmer settings it's firm and sure-footed enough for occasional track driving. Whether you plan to track your car or not, you'll love the handling transformation of the PSS10.
To insure maximum performance, these systems utilize Bilstein's superior monotube gas shocks, featuring:
Largest available piston diameter for greater sensitivity and precise control.
Patented digressive piston head design and deflective valving instantly reacts to changing road conditions.
10-way adjustable dampening knobs that "click" from soft to hard with no tools or jacking required.
Monotube design dissipates heat more effectively than a twin tube shock for cooler, more efficient operation and longer life.
Weather resistant coating to resist oxidization, and ensure long life.
Lighter weight reduces wear and tear on suspension components.
Ride height is adjustable from -1.0" to -1.75" front & -1.0" to -1.75" rear (minimum 1" lowering)
Wrenches to adjust front and rear ride height included!
10-way hand-adjustable shocksThe Bilstein PSS10 Suspension provides the ultimate in performance tuning. The fully-adjustable monotube gas shock absorbers offer a selection of TEN precise compression and rebound settings, from comfort to competition. Each setting "clicks" into place, and a labeled indicator lets you know exactly what setting you are on, without any counting of clicks. The front and rear progressive rate springs allow accurate adjustment of the vehicle ride height and center of gravity for the level of performance you seek.
Now you can enjoy the kind of precise suspension tuning formerly available only on race cars. The PSS10 system puts you in complete control. Whether it's a weekend of competition or the daily commute, absolute handling and control are just a few twists away. On the softest setting, this suspension is amazing compliant for street driving, while the firmest settings tighten your BMW into a track carving road-course handler.
This coilover kit fits the following BMWs:
  • 2014+ F22 BMW 228i M235i - Not for cars with EDC
*EDC Delete module required for cars with EDC
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831
Contact: sales@supremepower.com :: Shop# (714)632-1951
Sales & service of BBS Street & Motorsport products.
BBS Highest Volume Dealer 2015 thru 2022
All the top brands at the prices and service you can count on. Professional installation.
      07-08-2015, 06:39 PM   #2
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
What does the EDC delete module look like?
Also, I was told that one EDC is deleted it cannot be reversed. Or could be but requires a lot of splicing and work.
      07-08-2015, 06:56 PM   #3
supremepower
Supreme Leader
That may be the case if you code it out, but the edc delete module is box that holds the programming to remove the suspension light. Simple plug-in unit
SupremePOWER
      07-08-2015, 06:58 PM   #4
ocN55
ocN55's Avatar
So if I simply use the edc delete module any suspension light will clear? And when I go back to stock suspension, I can just unplug the module and have EDC again?
      07-08-2015, 09:35 PM   #5
scrape1
70
Drives: '14 228i M Sport, '04 X3 3.0i
How much? How do these compare to the KW V2?
      07-08-2015, 09:48 PM   #6
supremepower
Supreme Leader
Plugs directly into the sensors during suspension install, remove when you wish to go back to stock simple and quick
SupremePOWER
      07-08-2015, 09:49 PM   #7
supremepower
Supreme Leader
PM coming your way!
SupremePOWER
      07-10-2015, 06:13 PM   #8
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Please send me a PM (to zip 98327) for the PSS10 kit with EDC delete modules. Also, your explanation of the EDC delete modules clears up a lot of questions I had as well. Thanks much!
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      07-10-2015, 06:16 PM   #9
supremepower
Supreme Leader
No problem. I'll PM you right now
SupremePOWER
      07-14-2015, 06:37 PM   #10
hoppy6698
hoppy6698's Avatar
Do you guys sell KW coils as well? I am reading that the KW V1s are softer on daily drives while the B14s tend to be more track oriented. Is that the typical observation between the two sets?
      07-14-2015, 07:53 PM   #11
supremepower
Supreme Leader
I've heard the other way around. KW is typically the stiffer suspension when compared to Bilstein.
PM coming your way
SupremePOWER
      07-15-2015, 10:02 PM   #12
BD_F22
BD_e92
Drives: 2015 m235i xDrive
Any coilovers available for m235i xDrive yet?
      07-15-2015, 10:17 PM   #13
supremepower
Supreme Leader
Yessir, Bilstein B14 Part #: 47-207233
SupremePOWER
      07-16-2015, 07:24 AM   #14
BD_F22
BD_e92
I'd imagine I would need the EDC delete module as well correct?
      07-16-2015, 11:28 AM   #15
supremepower
Supreme Leader
EDC Module will be needed if you have adaptive suspension
SupremePOWER
      07-22-2015, 12:05 AM   #16
Bam226
105
Drives: BMW 228i M sport
The V1's are not stiff at all. Very similar to stock.
      08-01-2015, 10:35 AM   #17
BD_F22
BD_e92
Anyway you could provide the link or info as to which EDC module would work?
      08-02-2015, 02:53 PM   #18
supremepower
Supreme Leader
The KW EDC Module will work.
http://www.kwsuspensions.com/product...ete-units.html
SupremePOWER
      08-06-2015, 06:40 AM   #19
Csmoove195
Csmoove195's Avatar
Drives: 2013 335is AW/CR 6 Speed
I've have the b14's installed on my car for over 4 months and I couldn't be happier with the ride quality and drop.
      08-29-2015, 05:00 AM   #20
kanucks
14
Drives: 2015 BMW 228i xDrive
Would this also work on the 228xi? If so, could you please PM price and shipping to 98281? Thanks! BTW, how do the B14, B16 and PSS10 differ in terms of suspension?
      08-30-2015, 08:25 PM   #21
supremepower
Supreme Leader
Adjustability and performance
PM with price coming your way
SupremePOWER
      11-25-2016, 08:47 PM   #22
FakeM2
15
Drives: Manual M235
would you say these are better than st/kw for performance?
2addicts
