Network guys
07-08-2015, 01:42 PM | #1 |
684
Rep 4,261
Network guys
Hey I'm trying to setup a specific open port for downloading torrents. Anyone able to offer any advice. OS Win7 64 bit and Virgin Media Superhub.
cheers
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
07-09-2015, 04:08 AM | #2 |
283
Rep 2,343
I'd suggest UTorrent client for one. Select the port to open in the application itself. MAke sure the port is whitelisted on the windows firewall. Encrypt the traffic (option in the agent) to limit detection by some ISPs who don't like that kind of traffic for whatever reason.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
07-09-2015, 04:09 AM | #3 |
283
Rep 2,343
May help
http://www.dummies.com/how-to/conten...-firewall.html Can't recall if the applications adds itself.
07-10-2015, 02:25 AM | #4 |
93
Rep 1,568
First off, i have no experience of the Virgin Home hub you have, we do not come across any of these in the Business world.
But normally when we have a port Issue, the steps we take are first to turn off all firewalls (Temp) to see if we can connect. If not it is not a open port issue! If you can connect, then you have to know what prot you need to allow through The torrent site should advise what port or range of ports to open and whether the traffic is TCP or UDP (Or both). Then place an 'Allow' in the windows firewall first and test connectivity still exists. The open required port on router (or range). What may be better than willy nilly opening ports is to port forward that port to you PC internal IP address, then that port is only open to your PC and not the rest of you network at home (If you have one). As i said i am not aware of the way the Virgin Router (Hub) operates an you may not be able to NAT or Port forward. BT Home Hub can, so i would imaging Virgin will allow this to be done. Finally test connectivity and you should be good to go. Word of warning ....SOME, (and again i am not sure about Virgin) ISP will not allow traffic from torrent sites, or they do and then monitor what you are pulling down (Know what i mean??), so you may be advised to look up using a Proxy Browser, where you connect via a foreign IP address! Can still be tracked, but the tracker needs to have some sophisticated equipment and dedication to track you, and of course the desire!!! HTH Waspo
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you" |
07-10-2015, 01:24 PM | #5 | |||
684
Rep 4,261
