07-06-2015, 11:57 AM | #1 |
BimmerPost Supporting Vendor
3308
Rep 22,755
getBMWparts.com | Dinan F8x M3/M4 Lightweight Tubular Adjustable Anti-Roll Bar Set!!!
getBMWparts.com | Dinan F8x M3/M4 Lightweight Tubular Adjustable Anti-Roll Bar Set!!! Plus Free US Ground Shipping!!! Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan® tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Front Anti-Roll Bar Add a 32mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable from 57% to 103% stiffer than the stock bar. This 4 hole bar can be mounted in 7 different positions with supplied adjustable end links. Benefits: + Less Body Roll + More Mechanical Grip + More Stable At Limit + Large 32mm size (stock bar is 24.7mm) + 4 hole bar with 7 possible positions on the bar w/ supplied adjustable end links. + Tubular (Hollow) Construction Includes: Lightweight Tubular Adjustable Front Anti-Roll Bar, Adjustable End Links, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings. Rear Anti-Roll Bar Add a 24mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time.This anti-roll bar is adjustable from 0% to 13% stiffer than the stock bar. This 3 hole bar can be mounted in 3 different positions with stock BMW end links. Benefits: + Less Body Roll + More Mechanical Grip + More Stable At Limit + Large 24mm size (stock bar is 22.9mm) + 3 hole bar with 3 possible positions on bar + Only tubular anti-roll bar with a large range of adjustment on the market + Tubular (Hollow) Construction Includes: Lightweight Tubular Adjustable Rear Anti-Roll Bar, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings. Available in our Dinan Catalog Here!!! *We'll match (and try to beat) any competitor's pricing on Dinan Performance Products!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! Last edited by Evan@Tischer; 03-24-2021 at 04:00 PM.. |
07-06-2015, 11:59 AM | #2 |
1205
Rep 2,105
Drives: M4 MW/SO 6MT, E46 M3 AW/IR 6MT
So tempting
MILA | E46 BMW M3 | AW/IR | 6MT | KW V3 | CSL | Vorsteiner |
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust | |
06-02-2016, 02:20 AM | #7 |
172
Rep 283
Drives: Multiple M Cars
Pm for price shipped to 94108
Tags |
dinan, dinan roll bar, dinan suspension, getbmwparts.com, tischer |
