07-02-2015, 11:16 PM | #1 |
84
Rep 193
Coding doesnt even work for me??
Hello. I have the most recent pdzdata I believe and Esys 3.24.3 and Ive gotten the seatbelt warnings to go away, but despite having set ASD to F80 and S55, I am 100% no sound change occured, even though I coded FDL succesfully.
FA is green and active. I save after making edit to CAFD FDL, then I code fdl when it is ready. ASD doesnt work. HUBT changes to Video arent working, it gives me a error in transaction message #207. Even simply attempting to change the startup emblem logo gives me a transaction error. Am i doing something wrong? Someone please help |
07-02-2015, 11:38 PM | #3 |
1399
Rep 5,262
when you read the coding data of the ASD after you coded do you see the F80 and S55 values?
Maybe you have HU_NBT2 are you using the launcher ? |
07-02-2015, 11:39 PM | #4 |
1399
Rep 5,262
07-03-2015, 12:18 AM | #5 | |
84
Rep 193
Other systems work, except HU-NBT which is the main one I'd like to mess with alongside with ASD. Is ASD for F80 not working caused from the launcher and HUNBT2?? Yes sir, my F80+S55 settings are entirely correct. I even changed some HIFI and US/ECE settings and copied another persons settings from a video that worked for him but it didnt make a real noticable change for me or any change at all, in fact I think it may have disable ASD for me altogether Please help me with VO coding step by step if it is the key |
07-03-2015, 12:56 AM | #6 | |
1399
Rep 5,262
ASD should work fine.... VO coding will not solve any of those issues, VO coding is for when you want to code things like Enhanced bluetooth or options that come from factory... |
07-03-2015, 01:16 AM | #7 | |
84
Rep 193
Model range is f80 and engine set to s55 |
07-03-2015, 09:49 AM | #8 | |
1399
Rep 5,262
If you want you could VO code the ASD module... that will reset all the coding on the module the factory settings.... you can see instructions for vo coding here http://www.2addicts.com/forums/showthread.php?t=997749 make sure you vo code ONLY the ASD and not the whole car!!!! |
07-03-2015, 04:35 PM | #9 | |
84
Rep 193
Is there a step by step for this? I am not certain how to VO code. Well I know because I know how an M4 sounds like. Ive heard it from the inside live. And the M4 videos online and 235 with F80 sound are almost identical and difficult to tell apart, mine sounds nothing like it or as if no change occured or the ASD was turned off. I have a 2015 M235 |
07-03-2015, 04:53 PM | #10 |
1399
Rep 5,262
It's in the link I posted
Connect => Read FA => Activate FA => Read VCM => Right-Click on ECU you want to code i.e. HU_NBT (the ECU itself not the underlying CAFD) => Select CODE. |
07-03-2015, 05:16 PM | #11 | |
84
Rep 193
My default values are F22 with N55 N55 Branded hifi Construction stage equal or later than 7/13 Unbelegt niche aktiv if any of these make a difference. I am only gonna change it to f80 and s55b30 |
07-03-2015, 05:25 PM | #12 |
84
Rep 193
OK I hear the difference on windows up. Still doesn't sound like the m4. I recorded a video and compared side by side my video vs actual m4 and coded m4 sound videos, and mine sounds nothing like the same... versus my stock m235 sound videos I recorded from rhe cabin souns just like other m235i videos
07-04-2015, 09:57 PM | #14 | |
1399
Rep 5,262
So what do you see at startup? |
07-04-2015, 11:56 PM | #16 |
1399
Rep 5,262
07-05-2015, 12:33 AM | #17 |
663
Rep 1,976
Drives: 2020 G20 320i M Sport
I think HU_NBT2 still needs development because I can't get the startup emblem to change either. It's just like how Alpina, Mini and Rolls Royce never worked until 51.3 came out.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
07-05-2015, 01:37 AM | #18 |
84
Rep 193
Heck, Id say any HUNBT2 cars have a flawed ASD system. I will definately record a video or two to prove it. The F80 sounds are incorrect, so are all the other ones as well.
07-11-2015, 03:35 AM | #19 |
84
Rep 193
Here is my default M235 sound
http://vocaroo.com/i/s0aObFl2FoxR And here is the supposed S55/F80 http://vocaroo.com/i/s03aQIKHT6Wy Sounds nothing like what it should sound like. Doesnt even sound like a S55. It should sound something like these. Is it something to do with the Pszdata? How come I cant get mine to sound anything like the above? |
07-11-2015, 10:39 AM | #20 |
1399
Rep 5,262
07-11-2015, 10:41 AM | #21 | |
1399
Rep 5,262
If you read the ECU again... do you see the changed values ? |
07-11-2015, 02:42 PM | #22 | |
84
Rep 193
Please try yourself and post on vocaroo and let me compare your S55/F80 sound |
