V2 - Limp Mode - Superknocking Codes
02-16-2008, 10:05 AM | #1 |
Pave The Rainforest
269
Rep 1,197
Drives: Wagon
A few weeks back I was doing a highway pull in 3rd. As I shifted into 4th, I went into limp mode and the "half engine power" light came on. I turned the car and turned it back on. Limp mode was gone and the light went off.
This past Tuesday, I was on the highway having a little fun and as I floored it in 5th (around 120mph) the car just shuddered and did nothing. But as I let off a little bit, the car ran like a beast. So, I had the car in the shop to see what the deal was with the half power light and I had "superknocking" codes on ALL 6 cylinders in the mid 4k RPM range. Also it said to replace the plugs. I will have the plugs replaced under warranty and load a new map (January 9th or 10th version?) and start doing some datalogs. Here are my current settings -v2 -6mt -speed limiter removed (December 2Xth map) -95% settings -3-4 gallons of 100 octane on every fill up -BMC Air Filter -FAKE eisenmann race exhaust
Sold: 2015 Pyrite Brown M3
Sold: 2020 Sunset Orange M340i Xdrive Sold: 2021 Bluestone 540i Xdrive Msport |
02-16-2008, 03:31 PM | #4 |
136
Rep 1,954
Drives: 2020 X3M Competition
shiv recently said there is a problem with using the v1 green loom as the speed delimit wire. Take that out, load a speed-limited map, and see if the problem persists.
2020 F97 X3M Competition (current) - 2018 F80 M3 Competition - 2015 F82 M4 - 2012 E82 135i - 2010 E92 335i - 2007 E92 335i
02-16-2008, 08:47 PM | #7 |
Rep 89
Booster
Not sure if I am have something similar as I am not even sure what knocking sounds like... I am on V2 and if I do a pull from 4th to 5th gears, I will get a limp at redline and the engine starts to run bad like it is misfiring...turn the car off and on again and it disappears. With 1.47, when I had limp modes, the engine still ran smooth but with a lot less power Is this what you meant by shuddered? Also, can anyone describe what knocking sounds like? Shiv did say like bees in a can but that gives me the impression that it is quite high pitch? |
02-16-2008, 08:57 PM | #8 |
Pave The Rainforest
269
Rep 1,197
Drives: Wagon
Nope. I work for the dealer...
Superknocking is the the BMW code that was stored. You can really hear a ticking noise at start-up and in 1st and 2nd gear when driving next to buildings and what not.... The shuddering was kind of like I was flooding the car. Too much fuel than the engine could handle.... I NEVER had a limp mode issue with 1.47...
