06-26-2015, 09:34 AM | #1 |
3896
Rep 3,124
Dinan Sway Bar Set (RWD Only)
Lightweight Tubular Adjustable Anti-Roll Bar Set For the F22 228i and M235i (RWD Only) Part Number: D120-0585 Applications: F22 228i, F22 M235i, F30 320i, F30 328i, F30 335i, F32 428i, F32 435i, F33 428i, F33 435i, F36 428i, and F36 435i (RWD ONLY) Product Page / Pricing: http://www.dinancars.com/product/d12...ries&mid=1183/ Release: Date: Available Now. Description: Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Front Anti-Roll Bar Add a 28mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable up to 45% to 97% stiffer than the stock bar*. This 3 hole bar can be mounted in 3 different positions with stock BMW end links.
Includes: Lightweight Tubular Adjustable Front Anti-Roll Bar, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings. Rear Anti-Roll Bar Add a 19mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time.This anti-roll bar is adjustable up to 84% to 474% stiffer than the stock bar*. This 3 hole bar can be mounted in 3 different positions with stock BMW end links.
Includes: Lightweight Tubular Adjustable Rear Anti-Roll Bar, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings. Last edited by Dinan_Engineering; 06-26-2015 at 11:20 AM.. |
06-29-2015, 08:10 AM | #5 |
381
Rep 2,388
From what i've read install on these is much more time consuming than springs? Is that correct?
Would love to do dinan springs/sway bars but install time on the sways is 'swaying' me the opposite direction edit: see what i did there |
06-29-2015, 09:18 AM | #6 | |
3896
Rep 3,124
Excellent pun btw. Very 'dad' joke-esque which I appreciate. lol |
06-29-2015, 09:30 AM | #7 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
6 hr install at $100/hr....
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
06-29-2015, 11:31 AM | #8 |
450
Rep 845
