06-25-2015, 07:41 AM | #1 |
89
Rep 167
Bilstein coilovers installed
First thread started ever so bear with me. I had installed bilstein coilovers a few weeks back and I thought I would share pictures. If im missing anything and I'm sure I am, let me know.
Im loving the ride quality, much better than stock. The car is more responsive, you can feel a noticeable lower center of gravity when driving. There's less body roll, and takes corners much better as well. I do have a minor issue or 2: 1. The car is maxed out on threads on the rears, I can fit a finger in there. So it may not go as low as you may like it if super low is what you're aiming for. I may cut the springs but Im still on the fence. These are able to lower the suspension by about 2 inches in the fronts and rears. 2. When you hit a pothole, you're going to know about it. (Although I have low profiles)The ride quality when daily driving is way above stock, however potholes are less forgiving. Coming from 17's and run flats to 19's, low pros, and coils, the ride was night and day. For the better I believe, despite the way I cringe when I see a pothole coming up. I live in New England, so the roads especially on the highways and parkways are terrible. On the flip side, the ride driving on a decent general street with little bumps or cracks or uneven streets are much smoother driving over, almost as if gliding right over. This may seem biased but I don't have a lot to compare to in regards to other coilovers, just stock sport line suspension. I got them from Jeff from awe tuning who had them for the lowest price I could find at the time and he was very helpful. The part number's 47-207233 if anyone was thinking about pulling triggers. Bottom line if you want quality parts, a decent price, a noticeable drop, and better daily driving ride other than major road obstacles, these are great. Last edited by Csmoove195; 06-25-2015 at 08:04 AM.. |
06-25-2015, 08:37 AM | #10 |
82
Rep 219
looking good! Tim told me about your car but I haven't seen you around.
You should try removing the rear perches before cutting the springs, if you still have them in place |
06-25-2015, 08:54 AM | #11 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Cutting the spring, other than shoddy workmanship, will alter the characteristics of the suspension. These springs/dampers usually are of the progressive nature, meaning that as they compress more they offer a different resisting force (F=kx). If they are cut 1" shorter, that is 1" less of travel they will have and consequently the resulting force is different during that event and there will be different damping results, probably out of the design range of the damper... i.e. worse ride quality and/or bottoming out.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
06-25-2015, 09:18 AM | #12 |
89
Rep 167
Thanks man. But I didn't even know anyone else had a 2 series around my way in CT lol. I commute to stratford on 95 every single day early in the morning and never get back home until sundown, I never see any 2's. I can ask tim but I'm sure that the perches are still on the car.
06-25-2015, 09:21 AM | #13 | |
89
Rep 167
06-25-2015, 03:11 PM | #14 |
125
Rep 356
Please DO NOT cut the springs! You can easily convert to a different spring that is shorter. Don't cheap out and cut them.....been there, done that.....it sucks!
06-25-2015, 03:19 PM | #15 | |
82
Rep 219
06-25-2015, 04:12 PM | #16 |
89
Rep 167
95 is all I commute on lol but if you're planning on going to the country creamery anytime soon let me know, it's every Sunday
06-27-2015, 03:24 PM | #18 |
918
Rep 2,710
Drives: MB E350 4MATIC Estate
I agree with everyone that has said to NOT cut the springs. I think it looks nice the way it is and I know it works well, which is more important anyway.
06-29-2015, 05:47 AM | #20 |
89
Rep 167
06-29-2015, 05:52 AM | #21 |
89
Rep 167
Thanks for your input, If it could damage the car's dampening system or make for a harsher ride, I'm not going to. I'm glad I get steered in the right direction around here.
06-29-2015, 09:30 AM | #22 |
NewFinishColumbia/detailer
604
Rep 2,096
That's cool. Thanks for the reply. I'm looking at these or the KW's that GSR is using for track duty.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
