06-23-2015, 09:02 PM | #1 |
Family Man
14
Rep 126
Stability Control
So one of the most frustrating things on the 135 is the stability control is either all on or off. At the track it intervenes way too early, and turning it off entirely is not the most comforting thought. Is the 235 the same deal? Or is there a proper sport mode that lets you oversteer a little before the system kicks in?
[SIGPIC][/SIGPIC]
06-23-2015, 09:37 PM | #2 | |
Joint Chiefs of Staff
24295
Rep 190,975
06-23-2015, 10:36 PM | #3 |
312
Rep 818
In the 135, don't you just press the DTC button by the hazard lights and that turns a portion of DSC off? Then you can hold it to get DSC off IIRC...
If so, the 2er is basically the same. Press the button (Now by chassis mode buttons by shifter). Press it once, you turn traction mainly off and a little bit of stability off too but it reels you back in after you've swung the rear out a bit. Press and hold and you get DSC off, which is traction & stability fully off and you're completely in charge of the car. In the 2er you can either press the traction button or put it in Sport+: both accomplish about the same thing except in Sport+ you get all the sport chassis/drivetrain settings. |
06-24-2015, 03:16 PM | #4 |
3441
Rep 79,211
In the 135i, pressing once would leave stability on but turn traction control off. (same for 335i).
Holding it down for about 3-5 seconds would turn the system completely off. It should function in the same manner on the 2 series. |
06-29-2015, 12:46 PM | #5 | |
Family Man
14
Rep 126
i havent seen an owner's manual yet on the 235, but am hoping that tge Sport+ mode in addition to turning off the traction control loosens the stability control to allow a little drifting
[SIGPIC][/SIGPIC]
06-29-2015, 01:18 PM | #6 |
1539
Rep 3,332
http://www.2addicts.com/forums/showp...9&postcount=22
Refer to that table for better info on what the different modes do. In sport+ the stability control is reduced - it allows you to get a bit of the back end out before it will pull itself back inline, which is what you are looking for. With that said, on the track I would recommend turning the DSC off completely. 1 - You get the added benefits of the eLSD 2 - You can an honest understanding of what the car is doing at the limit, and that understanding will make you understand the limits of the car much better. Running in sports plus keeps the computer from keeping you out of trouble, but as a result it means you'll push the car to a point it doesn't want to be, and may not realize the computer is sorting out your mistakes. Being able to start slow and work your way up in a safe environment will mean you'll understand more readily what the car is communicating to you and how to handle it when it does step out. This is a very balanced car, and with the stock staggered tires will want to understeer a bit more than normal which makes it easy to start driving fast without constant fear of ending up backwards.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
06-29-2015, 01:25 PM | #7 | |
60
Rep 736
2011 335 E90 MSport PPK - retired
2008 M3 - retired 2007 335 E92 - Buy back 2007 X3 MSport - retired 1995 M3 - retired |
