06-18-2015, 03:58 PM | #1 |
BimmerPost Supporting Vendor
8067
Rep 18,788
Drives: BMW
▀▄ eas | Power Trio: ESS E-Tronic, ER Catless Downpipes, Macht Schnell EVC - $2250
Triple Threat Combo - only 3 kits at this price!
$̶2̶5̶6̶5̶ $2250 includes FREE SHIPPING or FREE INSTALLATION! Three of the most popular performance items all rolled into one combo: + + Evolution Racewerks Competition Series Catless Downpipes + ESS E-tronic Tune + Macht Schnell EVC Module = instant win ESS Tuning - S55 E-Tronic Tuner - BMW F8X M3 & M4 https://europeanautosource.com/ess-s...f8x-m3-m4.html The ESS E-tronic Tuner provides a safe and simple solution to add power to the already potent F8X M3 & M4. Unlike other products on the market, E-tronic is a sophisticated multi channel controller that has RPM and MAF integration. This allows for full control of boost at all RPM ranges and proper AFR calibrations without the need to splice into any factory wiring. OEM grade hardware is used to provide high quality, safe, reliable power with excellent driveablility. Pre-set calibrations provide for a very simple installation without the need for setup or adjustments once installed. E-Tronic can be disabled with the included plug or removed at anytime, allowing customers to keep the factory warranty. Includes ESS branded thumb drive. Features - Instantly adds 50-60whp & 50-60wtq - Preset calibrations for easy operation - Simple to install and remove, no wire splicing - Includes termination plug and thumb drive Evolution Racewerks - Competition Series Catless Downpipes https://europeanautosource.com/evolu...f8x-m3-m4.html Restrictions in the exhaust system robs horsepower and torque especially on turbocharged cars. Thus, removing as much exhaust flow restrictions will increase horsepower and torque significantly. The factory catalytic converters found in the factory downpipes are a big culprit of this and is a major exhaust flow restriction. The factory catalytic converters are made up of catalyst material formed into "honeycomb" weaves. Exhaust gas must pass through these tiny "honeycomb" weaves on their way to the exhaust system thus causing a major exhaust flow restriction. It also causes turbulence after the catalytic converter which causes the exhaust flow to slow down (which increases restriction). By replacing the factory downpipes and catalytic converters with our Competition Series Catless Downpipes, more power is unleashed! You will feel the difference instantly. Features - Better throttle response and faster turbo spool up times. - Mandrel Bent piping. Smooth transition to the exhaust system. - 100% Stainless Steel Construction - 100% TIG welded for better quality welds - Precision CNC machined turbocharger V-Band flange. - Brushed Finish - Compatible with the factory or aftermarket exhaust systems. - Track tested durability. - Includes all hardware for complete installation. - Limited Lifetime Warranty. Macht Schnell - Exhaust Valve Control (EVC) Module https://europeanautosource.com/macht...vc-module.html Compatible with all exhaust systems (OEM or aftermarket) that retain the factory EVC control, the Macht Schnell Exhaust Valve Control (EVC) Module allows FULL user control of your exhaust system at the touch of a button. No clumsy key FOBs or additional equipment is needed - this is a 100% integrated solution and the first of its kind for current BMW models. BMW's Exhaust Control Valve is integrated at the exhaust system end pipe of the muffler. The exhaust flap reduces the noise level when the engine is idle and when the engine speed is close to idle. This reduces the outlet noise to improve comfort to the driver. The reduction on a stock exhaust system is ~8dB on the stock exhaust system. The Macht Schnell EVC Module supports the following features: - FULL control over Exhaust Valve Control at the touch of a button - on the fly or while stationary - User settings configurable by computer or while installed in vehicle from driver’s seat - Open/Close Exhaust Valve at YOUR command, or use BMW's factory profile for Exhaust Valve Control - Optional User-defined Valve Control Setting at startup (Open/Closed) or default to OEM operation - Quiet Cold Start in mornings compared to OEM operation - Integrated USB port for feature updates and configuration changes - InstallAID integrated LED confirms proper installation/operation while in use - Regulated internal power supply enters sleep mode to prevent unnecessary power drain while vehicle is parked - Easy 20-minute installation process with no wire cutting - No dealer visits or coding required after installation - Completely removable at any time Simply press the BC stalk for +2 seconds to change EVC modes. This is the feature that should have been standard from BMW. Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier's Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell! Contact Info: Phone: 866.669.0705 Email: info@europeanautosource.com Website: http://www.europeanautosource.com All items are in stock and ready to ship or install NOW. Feel free to contact us via PM, email, or phone if you have any questions - or to schedule your install today!
06-18-2015, 06:53 PM | #3 |
8067
Rep 18,788
Drives: BMW
One kit gone. Two remaining.
06-22-2015, 04:53 PM | #4 |
2895
Rep 21,660
One set left for immediate shipping or install
Who is going to the be last one to get in on this deal?
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
06-29-2015, 12:14 PM | #5 |
2895
Rep 21,660
Thanks for the inquiries
Due to popular demand one more combo set added to our sale PM to get yours today
07-17-2015, 01:34 PM | #6 |
2895
Rep 21,660
Power Trio In stock and ready to ship
One more left! PM today for details
Tags |
eas, ess tuning, macht schnell evolution racewerks |
