06-13-2015, 11:31 PM | #1 |
46
Rep 236
Can someone please tell me what I'm doing wrong with my coding?
Hey guys,
I followed all the directions from Shawn's guide and was able to get the connection with the car through VIN and everything looks fine. I followed the directions and was able to get to the step where you actually edit the FDL file, but when I actually try to code something, I can't find any of the functions: As you can see, I don't see any function names and when i dive deeper into the structure, they are all dots. I'm using 3.24.3 with PZdata lite. What I am doing wrong? Thanks in advance! |
06-14-2015, 12:52 AM | #2 |
46
Rep 236
I'm using the latest version of the Esys Launcher (2.07).
I did notice that the car series reads F999 and I can't change it. Is it not reading the type of car correctly? Should it be F20 for the f80/82/83? |
06-14-2015, 08:51 PM | #3 |
106
Rep 191
I know it's not much help but I do remember being able to select F80 in the launcher.
06-15-2015, 10:17 AM | #4 |
46
Rep 236
I figured it out (i.e. Shawn sent me the solution ). If anyone is having the same issue, just change your computer system date to 4 days in the future. When you do that, you should be able to select the car series on ESYS. When you're done coding, just switch back the date.
06-15-2015, 05:34 PM | #5 | |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
06-15-2015, 05:54 PM | #6 |
46
Rep 236
No idea, but it worked after that small hack. Before, under the car selection, it would default to F999, but after changing the date, I was able to select F80 which decoded all the truncated values.
