strange 30ff. light throttle
06-11-2015, 10:07 AM | #1 |
261
Rep 776
I am getting an occasional 30ff low boost only under light throttle conditions. If I'm cruising at a speed for a while and giver her a little gas I get the 30ff. Hits target 16psi no problem at full throttle. (map 2)
It was happening before with dinan stage 2, and seems a little more frequent being jb4, fbo now. I changed both boost solonoids, vacuum lines and chargepipe still happening. |
06-11-2015, 10:46 AM | #2 |
533
Rep 2,872
Could be vacuum related, test the vacuum system to make sure there's no hidden leaks. I see you already did the common vacuum related things, but did you replace each line?
Other than that, maybe a faulty sensor? |
06-11-2015, 12:00 PM | #5 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
Contacted Terry and he told me to upgrade to the newest firware. Got it fixed. Make sure you have the newest firmware
06-11-2015, 12:28 PM | #6 | |
261
Rep 776
I think something is sticking, either wastegate or dv. It happens immediatly after giving some gas radomly. |
06-11-2015, 12:59 PM | #7 |
533
Rep 2,872
Even though this issue was prior to the JB4, make sure all DUTY BIAS values are set to 0 in the interface. Assuming you're using firmware 28_7 & up.
06-11-2015, 01:17 PM | #8 |
261
Rep 776
