JB4 First Time Logging
06-09-2015, 01:52 PM | #1 |
48
Rep 342
So I finally got to logging my car today, although I don't know how to read a log so I was hoping for some help from you guys.
To begin I'll add some info about my car: 2010 335i xDrive AT with 20,000 miles Mods: JB4 G5 ISO VRSF DCI VRSF 3" Catless Downpipes VRSF 7" Intercooler Fuel used was 93 octane with 4 gallons of e85 mixed in. One thing I did notice about the log was that my targeted boost at 2200 rpms is 16 but only hitting 3. Could anyone verify? Here's the log: http://datazap.me/u/antoniogaj/log-1...log=0&data=1-4 |
06-09-2015, 03:16 PM | #2 |
20
Rep 115
Drives: 2011 E90 335 Xdrive 6MT
I'm not skilled at logging but I think the difference between target and actual boost at 2200 rpm is due to the fact that boost is not instant. It takes some time for the turbo to spool up and deliver full boost. Someone else might be able to chime in and say if you are delivering boost slower that what you should be given your mods.
06-09-2015, 10:25 PM | #3 | |
48
Rep 342
06-10-2015, 09:33 AM | #4 |
74
Rep 315
Drives: 2008 Deep Green 335xi 6MT
1.6 seconds for 15 pounds does seem a little slow. I did just notice that you started your pull at 2k rpm. Try starting at 2.5k, boost will build MUCH quicker.
How old are your turbos? I had 82k on my turbos, and the difference was night and day when they were replaced. I couldn't build stock boost before 3k rpm. Getting the car back, I could build boost in 6th gear, starting at 1500 rpm by 1800 rpm. Boost builds by the expansion of exhaust gases. It builds faster when fueled when open throttle vs. partial throttle. Your avg ignition looks great. Timing looks good. You should be maxing out map 5. FYI, enter 4 or 5 into 6-cyl timing logging to log timing on all cylinders. I use 4 and I have an early 2008. 5 doesn't work for me. 4 or 5 depends on which version of DME you have.
06-10-2015, 11:17 AM | #5 | |
48
Rep 342
06-10-2015, 11:47 AM | #6 | |
533
Rep 2,872
06-10-2015, 01:05 PM | #7 |
BimmerPost Supporting Vendor
24201
Rep 190,807
Boost looks normal to me.
Your LPFP is suffering though, hitting 40 at some times. I would keep an eye on it.
06-10-2015, 01:52 PM | #8 |
533
Rep 2,872
I'm on mobile so can't really see logs too well, but if that's the case, OP you should try lowering your E85 amount by a bit and see if the LPFP responds nicely, or buy an inline option.
06-10-2015, 01:58 PM | #9 |
3441
Rep 79,211
