Removal of obstacles to clean DCI question
06-08-2015, 11:58 PM | #1 |
24
Rep 283
Drives: 2009 E90 335i
I can build you a computer but automotive work is new to me. I need to clean my BMS DCI cones. Can I remove the battery cabling assembly (red arrows) with a flathead screwdriver to pop the three clips and pull it straight out without removing the cabin filter and cowl above it circled in green? With that out of the way a bit I should be able to reach the clamps holding the cones in place. Thanks.
2009 E90 335i 6AT / Procede / Vishnu DCI / Space Gray / Oyster Dakota Leather / Light Burl Walnut / / Sport, Premium, Cold Weather Pkg / Paddle Shifters / iDrive / Logic 7 / Park Distance / Comfort Access / iPhone Port/ |
06-09-2015, 12:21 AM | #3 | |
24
Rep 283
06-09-2015, 09:59 AM | #4 |
3441
Rep 79,211
It's probably easiest to follow the JB4 install guide as the first few steps involve removing the pieces in question:
http://burgertuning.com/instructions/JB4PnP.pdf The screws highlighted in green do not hold what is pointed to with the pink arrows. But yes, a flat head screw driver on the top side of the battery cables will unlatch that. You don't necessarily need to remove any of the above mentioned though. 2 clamps hold on the intakes, so just unscrew the clamps and the filters come off. Last edited by Jeff@TopGearSolutions; 06-09-2015 at 10:06 AM.. |
06-09-2015, 02:07 PM | #6 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
06-09-2015, 02:31 PM | #7 |
533
Rep 2,872
Agreed, I'm fortunate enough to have very big, but skinny hands some extension sockets don't hurt either.
06-09-2015, 11:01 PM | #10 |
352
Rep 2,050
For me I remove the cowl because it's hard to reach the screws on the DCI. Plus I like the make sure my intake fits tight
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
06-10-2015, 08:17 PM | #11 | |
421
Rep 1,643
2007 E92 335i MT
06-11-2015, 05:22 PM | #12 |
24
Rep 283
All good info. Thanks everyone. Yeah the dealer had taken them off and put them back on last so the screw to the back clamp is facing downward ;(. Will fix that this time around.
06-11-2015, 08:39 PM | #14 |
51
Rep 719
Be careful when reinstalling the back one. You don't want to dislodge your rear turbo inlet tube... I always take my cowl off for this exact reason.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
