The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Knocked headlight out of place?
      06-06-2015, 10:18 PM   #1
TheYuriPanda
TheYuriPanda's Avatar
74
Drives: 335i XDrive E90 2010
So I hit a very big pothole, durning the day. And later at night I turned my car on and I noticed my headlight being very low, restarted my car to see if the auto adjust would fix it and it didn't. So I drove home with very dark roads, and at home I tried to manually adjust it, when I tried to turn the knob with a flat head the headlight wouldn't move up or down, tried it on my other headlight and it would move. It still does move side to side when I turn (using high beams) I can see it turn.
      06-06-2015, 11:22 PM   #2
streetdreamz335i
streetdreamz335i's Avatar
Drives: 08 bmw 335i
Sounds like it fell out of its socket your most likely going to have to pull the headlight out to put it back in its socket
Shake & bake!!
      06-06-2015, 11:22 PM   #3
TheYuriPanda
74
How do I do this?
      06-06-2015, 11:23 PM   #4
streetdreamz335i
Drives: 08 bmw 335i
How do I do this?
There is alittle white ball in the headlight U just need to fit somthing in to push it back in if u search it it will come up
Headlight wasn't leveling - Fixed! http://www.e90post.com/forums/showthread.php?t=494479
Shake & bake!!
      06-06-2015, 11:35 PM   #5
335NJ
Drives: 2008 335i 6MT E90
If you have adaptive xenon, there's sensors under the struts (or in that area I believe). Could've knocked one loose?
      06-07-2015, 12:01 AM   #6
csu87
2134
Drives: 09 335xi
I had a broken little bracket thing when mine did this. Had it fixed under an extended warranty. If you have to replace it, don't go near the dealer. The warranty invoice showed $1700 worth of parts and labor to replace one headlight.
      06-08-2015, 12:25 AM   #7
streetdreamz335i
Drives: 08 bmw 335i
How do I do this?
So did u get it fixed?
Shake & bake!!
