P2E7C : Bit serial data interface, signal! Oil level INACTIVE! help
06-06-2015, 12:12 PM | #1 |
57
Rep 772
Hello everyone, so I had oil level Inactive and changed the sensor, and it's still Inactive after I changed the sensor and plus this code P2E7C : Bit serial data interface, signal.
Please help, what could it be. |
06-09-2015, 05:41 AM | #2 |
20
Rep 120
The alternator, oil level sensor, water pump, and intelligent battery sensor all communicate on the bit serial interface. Maybe check/clean connections of all those . I am have some bsd codes also but have not checked anything yet
06-09-2015, 06:18 AM | #3 |
267
Rep 1,203
This , I've seen a N54 water pump fry the BSD line, taking out the IBS and the DME along with it. I would check the water pump connection, for signs of corrosion/coolant. Check the ground points on the valve cover
06-14-2015, 12:05 PM | #4 |
57
Rep 772
any more ideas people?? alternator wires look good. And why would alternator wire make my oil inactive, wouldn't everything stop working if alternator ground wire is loose....
06-14-2015, 06:18 PM | #5 |
267
Rep 1,203
The alternator is controlled on the BSD line along with the Water pump & IBS, DME, oil level sensor. Did u check the water pump ? IBS ? How did you check the wire ?
07-12-2015, 11:44 AM | #6 | |
57
Rep 772
http://www.e90post.com/forums/showthread.php?t=1149542 |
