Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > ECU chiptuning + Vishnu procede rev3.. possible?
      06-05-2015, 11:32 AM   #1
montru
Italy
Drives: m4 f82
Hi Guys,
i have a 335i e92 04/2007 Europe AT Turbo Dynamics stage 1, supersprint total race exhaust, airbox gruppe M, Stett Chargepipe with BOV's BMS oil valve, Setrab Oil cooler, intercooler ETS 5 '' with ECU chiptuing.. If i install a Procede V3 with not ECU's original file, I have problems?
Or the procede rev3 fits and works just as well? i'm going put "9.10 upgraded turbo" map!
I need help!
Bye
      06-05-2015, 12:24 PM   #2
bryce-o
51
Drives: 2013 BMW 335is 6mt
The procede would work best if you flashed back to your original ecu file. Better yet, the backend flash offered by Vishnu.
Although, neither the procede or back end flash have been supported in a while.
Unless you already have the procede, I'd recommend looking into Cobb or mhd
      06-05-2015, 01:13 PM   #3
The Convert
43
Drives: 335i
Cobb or mhd don't equate to what he is asking. If you want to stack, you'd have better support using a JB4 on the piggyback side seeing as how you seem unfamiliar with things. If you were well seasoned on the tuning side of things, you'd be just fine with the procede as you wouldn't need support with it.
      06-05-2015, 02:01 PM   #4
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
dont call it chiptuning... wrong on this type of DME's
      06-05-2015, 02:09 PM   #5
WedgePerformance
BimmerPost Supporting Vendor
WedgePerformance's Avatar
Drives: Slot Machines.. Keep Taking $
Originally Posted by montru View Post
Hi Guys,
I need help!
Bye
You can use MHD to flash the car with a stage 2 or E40 map, then setup the Haltech / Procede to control boost. If you use the stage 2, you can add timing through the procede + or - 5 deg if I remember correctly. Let me know if you need any assistance. Crazy busy lately, but I'll try to help if I can.
      06-06-2015, 10:32 PM   #6
stanlalee
261
Drives: 07' E92 335i manual
I think that's the actual name of the european tuners tune.
http://www.chiptuning.com/en/chiptuning-bmw.html
      06-09-2015, 02:48 AM   #7
montru
Italy
Drives: m4 f82
ok guys, thank you very much.. I will buy a JB4
thank you enrita for my mistake, i'm not familiar with the translation of technical terms
