Coolant leaking probs!
06-05-2015, 09:42 AM | #1 |
18
Rep 187
I just had 3 coolant hoses changed and the radiator!!! This morning the coolant low came on and the tank was empty!!
PLEASE HELP. Idk what it is!!!! |
06-05-2015, 01:00 PM | #2 |
59
Rep 645
Is there a leak on the floor? Grab a flash light and look around.
It could be as simple as a defective part you just installed. other signs could be a crack in the waterpump... Last edited by blackturbo; 06-05-2015 at 01:01 PM.. Reason: more to add |
06-05-2015, 01:07 PM | #3 | |
18
Rep 187
06-05-2015, 04:44 PM | #5 |
52
Rep 335
with a leak that big you should be able to peak into the engine bay and look/listen for drips and spatter. when i replaced my radiator i needed to replace the o-ring on the lower connection with a slightly larger one as the stock hose would not seal properly. check there first.
06-06-2015, 03:34 PM | #7 |
291
Rep 2,189
Plumbing jobs including cars are a pain the ass, you can go through the trouble of doing all the work to find it's leaking.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
06-08-2015, 12:56 PM | #8 |
96
Rep 448
It seems as though they left a coolant hose connection loose or not connected at all. Did you have your water pump or coolant expansion tank replaced before the radiator and hoses? As others have said, take it back to the shop that did the install, but don't drive it, get a flatbed.
06-08-2015, 01:38 PM | #9 |
51
Rep 217
06-08-2015, 01:51 PM | #10 |
18
Rep 187
06-08-2015, 02:01 PM | #11 |
292
Rep 2,898
06-09-2015, 03:23 PM | #12 |
18
Rep 187
It got a little passed 250 but I shut the car down and had it towed
06-10-2015, 01:26 PM | #14 |
BimmerPost Supporting Vendor
24198
Rep 190,805
Glad you got it figured out before damaging your engine .
