Keep getting "engine Malfunction" light with no code
06-04-2015, 09:45 PM | #1 |
660
Rep 780
Whenever im cruising on the freeway in 6th gear, sometimes I will get the "engine malfunction reduced power mode". Mainly happens under half throttle ish. Mid boost (10psi). No codes pop up, nothing seems to be wrong except the dam "reduced power mode". Why cant it atleast throw a code so I know whats going on?
06-04-2015, 09:49 PM | #2 |
3441
Rep 79,211
How many miles on the spark plugs? What are you using to check codes?
You can usually find stored codes that start with an "H" meaning they aren't "present" but in "history". |
06-04-2015, 10:05 PM | #5 |
660
Rep 780
Plugs have maybe 2K on them max. I have a OBD reader but with no "real" codes nothing will pop up. I do have the MHD flasher off my phone though I guess I could take a look and see if that shows anything. Hmm
06-05-2015, 03:45 PM | #7 |
161
Rep 7,377
codes should be stored , do you have a piggyback with auto clear codes?
06-05-2015, 05:36 PM | #9 |
648
Rep 2,013
Did you check code w mhd codes?
Does engine mal happen on stock?
335i e92 TPC 19Ts
06-14-2015, 06:40 PM | #10 | |
660
Rep 780
The codes that MHD showed: 3100 Boost-pressure control, deactivation 2D25 manipulation cover, maximum air mass 2DED Power Management, Standby Current Control 30FE Turbocharger, Charge-air pressure to high Shadow codes: 2FA3 coding missing 2AAF fuel pump plausibility 29F4 Cat conv 29F5 cat conv 2 |
