VRSF FMIC install issues on 2011 BMW 335is
06-04-2015, 06:19 PM | #1 |
44
Rep 293
Was installing my VRSF FMIC today when I ran into an issue connecting IC to boost pipes.
First on passenger side am I supposed to to remove the OEM pipe and use the provided tube by VRSF. If so how do you remove it the clamp holding it on looks like it's unremovable.. Second, for drivers side the boost pipe connecting CP to IC is one piece, looks like the only way to use VRSF provided tube I'd have to actually cut this pipe, which I do not want to do.. First pic is reference from passenger side Second pic is drivers side |
06-04-2015, 06:28 PM | #2 |
51
Rep 747
Use a dremel tool to cut the band on the passenger side. The drivers side needs the j pipe that vrsf charges $45 extra for. You remove the whole lower charge pipe, and connect the j pipe to the upper charge pipe that goes to the throttle body
06-04-2015, 07:10 PM | #4 | |
51
Rep 747
06-04-2015, 07:36 PM | #5 |
44
Rep 293
Yea, found out I did order it (looked at my invoice) but wasn't sent to me, trying to resolve this now
As far as passenger side, is there a simple way of removing that "one time" clamp? |
06-04-2015, 07:58 PM | #6 |
291
Rep 2,189
Dremel with small cutting wheel.
Just go slow, you want to avoid hitting the pipe of course.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
06-05-2015, 12:34 AM | #8 |
42
Rep 255
Drives: Space Gray 335i E93
Passenger side can be removed by using flat head screwdriver and popping clamp no need to mess with cutting it off.
06-05-2015, 12:49 AM | #9 |
184
Rep 1,702
Drives: Audi TTRS, 335is
I cut mine with a dremel but you can easily pop it loose with a flathead screw driver as mentioned above.
