Limp Mode, Misfire, Engine Symbol, P312e
06-04-2015, 12:56 PM | #1 |
31
Rep 370
Hopefully somebody can help me out...
Yesterday I installed cat-less downpipes with no problems, went for a drive and everything was good. Later that night went out again and while WOT there was a few small stutters, then it got worse to where the car went into limp mode while showing the engine symbol on the cluster! I had no boost and was misfiring so bad the car sounded like a Subaru lol. Got home and restarted the car and it was acting normal for a little while but then returned to limp mode. My first impression was I damaged either bank 1 or bank 2 upstream o2 sensor, so I was hoping to see something like 1,2,3 or 4,5,6 misefires and an o2 ground negative codes.... but after using an AutoZone scan tool the only code that I got was a P312e "No DTC definition found"?? Previous to the downpipes and this problem I did have a SES light on for P2402 "Evap system leak detection pump control circuit high" I figure the car needs a new DMTL pump It starts right away with no hesitation. 2007 with 57K miles I no longer have any warranty for wastegate rattle, fuel injectors, HPFP or anything? |
06-04-2015, 02:08 PM | #2 |
533
Rep 2,872
06-04-2015, 10:50 PM | #4 |
31
Rep 370
Welp I drove the car some more to see if I could get any additional codes out and a cylinder 5 misfire came up.
This problem is intermittent, Weirdly enough the car randomly ran normal for a short period of time and had no problems doing WOT but then returned to LIMP mode the next time I started it??? No rhym or reason to it. |
06-04-2015, 11:17 PM | #5 | |
533
Rep 2,872
06-04-2015, 11:29 PM | #6 | |
31
Rep 370
Got #5 misfire Cleared the codes Started to run better and was able to go WOT with no SES light for a small period of time. Turned off the car for a few hours Came back to misfires worse then ever and limp mode. |
06-04-2015, 11:50 PM | #7 |
533
Rep 2,872
So if cylinder 5 only seems to miss after sitting for awhile, I'd think the injector is leaking. When you fire it up, that cylinder is chock full of fuel and misfires.
You can start by doing the normal misfire diagnoses, and replacing the plugs, but I'm leaning towards an injector here. Pull the plug in cylinder 5 and see if it looks like it's fouled, or a different color than the rest. Last edited by 335NJ; 06-05-2015 at 08:46 AM.. |
06-07-2015, 01:34 PM | #8 |
31
Rep 370
Welp got some more codes
P0306 - Cylinder 6 Misfire P0206 - Cylinder 6 Injector Open Circuit The number on them is 1353 7537317 - 10 Browsing online I found something that said any prefix 10 or below you have to replace all 6 at once? Prefix 11 or above you can replace a single injector.... Build date was 09/06 Last edited by Real Nice Guy; 06-07-2015 at 02:12 PM.. |
