EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      06-02-2015, 05:09 PM   #1
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
IND | Kohlenstoff Rear Diffuser DIY
Kohlenstoff Rear Diffuser Walkthrough
Up to this point, the aftermarket support for the F8X has been nothing short of stellar. Manufacturers and tuners alike have responded in a grand way and are delivering product to fill nearly everyone’s individual preferences. One such piece that was recently released is the Kohlenstoff LED equipped rear diffuser. Drawing inspiration from the circuit, this diffuser is equipped with a center mounted LED strip that is triggered by engaging the brake.
Below is a general installation guide for the Kohlenstoff rear diffuser. As always, we welcome feedback and alternatives. There are many ways to install components and the guide below provides insight into how our technicians remove these pieces. If at any point you do not feel comfortable with the installation process, then contact a body shop or your local BMW dealer for assistance.
Tools required:
  • Flat-head screwdriver
  • 10mm socket
  • 8mm socket
  • extension
  • ratchet or socket driver
  • nylon prybar
Step 1 – Remove Passenger Taillight
  • Step 1 - Pop the trunk and remove the plastic screw from the black cover between the taillight and trunk liner. (flat-head screwdriver)
  • Step 2 - With the screw removed from the plastic panel, remove this panel. This will show you the two 10mm nuts securing the taillights to the vehicle.
  • Step 3 - Remove the bolts with the 10mm socket
  • Step 4 - Now that the bolts are removed, the only thing securing the taillights to the vehicle is a round plastic tab. To remove this tab, carefully mask the outermost corner of the taillight. Protect both the paint and taillight. Take the nylon pry bar and lift the taillight using leverage.
  • Step 5 - Carefully pull the taillight away from the vehicle and remove the PnP connector on the back of the housing.
Step 2:
Now that the passenger taillight is removed, the next step is to feed the power and ground wire that will be used on the Kohlenstoff LED module. Feed the wire through the opening at the base of the passenger taillight area.
Step 3:
Work on feeding the wires through the passenger exhaust outlet. As you can see from the photos below, we draped them directly over the passenger exhaust tips. This will give you a good straight line connection to the Kohlenstoff module.
***PLEASE ENSURE THAT YOU HAVE PLENTY OF SLACK ON BOTH ENDS OF THE WIRES***
Step 4:
With the line in the correct location, it is now time to focus on the connections. You will be tapping into the PnP connector that connects to the rear passenger taillight. The two wires to focus on are the brown color coded wire and black/blue wire. Using two wire tap splice connectors, connect the red wire with the black/blue. After this is complete, use the second connector and mate the black wire with the brown wire. Photo breakdown below:
Red – Black/Blue
Black - Brown
Step 5:
Using two heat shrink sleeve connectors, we now focus on connecting the Kohlenstoff LED module with our black and red wires. Please be sure to rest the diffuser on an object that will not scratch the finish. Also, this is where a little extra slack is quite the luxury. This step is fairly simple. Strip the ends of the red Kohlenstoff wire and our red wire. Join these with the heat shrink sleeve connector. Now repeat with both black wires.
Step 6 - Removal of the factory rear diffuser
  • Step 1 – Using an 8mm socket, remove the BMW 8mm screws on the outside corners of the OEM diffuser
  • Step 2 – Gently pull back on the OEM diffuser one section at a time. This pressure will release the clips from the bumper.
  • Step 3 - Remove the 8mm bolts holding the center of the exhaust shield.
The below video shows this removal during the RKP diffuser install:
Step 7 - Install the Kohlenstoff rear diffuser
  • Step 1 – First, focus on clipping the center part of the diffuser into the factory slots.
  • Step 2- There are two bolts on both ends of the diffuser. Using the 8mm socket, tighten all 4 bolts (2 on each side)
  • Step 3 - Tighten the two center bolts
Step 8:
Before installing the passenger taillight, secure and protect all connections with electrical tape.
Step 9:
Install the PnP connector into the passenger tailight
Step 10:
Align the passenger taillight with the mounting tabs and push forward while applying light pressure.
Step 11:
Using a ratchet or drill install the two 10mm nuts. Then install the plastic cover with the rivet located at the top inside edge of the taillight.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
Appreciate 2
hC1001591.00
      06-02-2015, 11:04 PM   #2
Fellfromdsky
Fellfromdsky's Avatar
Drives: 2020 M2c - 6 speed
omg i need this diffuser lol
Current: 2015 F82 M4 | MW/SO | M Performance Parts / KW Sleeve / Hüper Drei 35 / Blackboxguard / Stormtrooper valvestems
Previous: 2011 e92 M3 | SG/FoxRed | ModeCarbon V2/ KW Sleeve/ Vorsteiner bootlid/ Arkym diffuser / Hüper Ceramic 15
Other Previous: F430, F355 & F328
      06-02-2015, 11:42 PM   #3
CaptBTKirk
Drives: 435i xDrive MSport
Great write-up. Any worries that the exhaust tips will be hot enough to compromise the insulation on the wiring (apart from my own ?
      06-03-2015, 06:48 AM   #4
evm3
56
Drives: M4 + others
Thanks IND for the install , I was looking for a more unique part to set it apart from other m4's.
Now to concentrate on performance upgrades.
      06-03-2015, 10:10 AM   #5
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
We apologize, but we did not get a photo of the solution for this concern. The wire is tucked on top of the heat shield over the exhaust.
      03-05-2018, 01:10 AM   #6
MCanadaE46
150
Drives: BMW M3 F80
Interested in this.
How complicated will it be to wire this up to turn on with the rear fogs?
I've done the LCI tailight upgrade and as well have done the emergency brake light mod (rear fogs flash during hard braking).
I'm not a fan of having them light up everytime I brake...but for emergency braking and for them to function as rear fogs it would much cleaner. Is this possible?
      01-22-2019, 05:42 PM   #7
WatashiEd
WatashiEd's Avatar
Australia
29
Drives: 2015 F82 M4 DCT
Nice products as always IND!
Is there any aftermarket connector / harness that we can buy to avoid spicing the factory taillight wiring? Just a bit of OCD and doesn't want to do any permanent mod to the car, and I return the call to full stock condition if needed
Sapphire Black M4 | iPE - Valvetronic exhaust | VRSF 3″ catless dp | Bootmod 3 Stage 2 | OEM LED alcantara steering wheel | OEM M4 GTS CF hood | Vorsteiner GT wing | M Performance CF splitter | Vorsteiner CF front lip | M Performance CF side skirt extension | 3D CF diffuser | OEM CF mirror cap | H&R lower spring | Rays Engineering TE37 Ultra Bronze 20x10F 20x11R
      01-25-2019, 03:22 PM   #8
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
Originally Posted by Nalen View Post
Interested in this.
You can code this on. There's a DIY on the forum. You already have the button on your dash to turn the rear fogs on and off.
It's good to be bad
      08-11-2020, 09:03 PM   #9
flexspec
flexspec's Avatar
367
Drives: F80 M3, E90 330i
So excited to have this diffuser installed. Of all the mods I have done, this one is the sweetest. Absolutely stunning!
Appreciate 3
      08-20-2020, 03:35 PM   #10
M3nmotion18
M3nmotion18's Avatar
Drives: 2018 IR ZCP BM3
2018 BMW M3  [9.87]
2021 MINI COOPER  [10.00]
2023 GENESIS GV60  [10.00]
2017 LEXUS RX350  [10.00]
Iceweasel,
Diffuser looks great! I might get this or 3D Design!!
flexspec367.00
      02-24-2021, 09:35 PM   #11
flexspec
flexspec's Avatar
367
Quick update on the diffuser - looks much better with a proper exhaust setup. Also - I had the exhaust wrapper in clear XPEL PPF.
I have no other comments. Overall a well made product that fits well.
Kudos to @houstoncarenthusiast for the awesome pics
Cheers!!
IG: @FLEXSPEC
      06-11-2023, 02:54 PM   #12
airkenny
Drives: 18' F80 ZCP Grigio Telesto
I've had these for over 4 years now and noticed quite a few led lights have died.
Any idea if there's replacement leds available? would hate to have to buy a whole new diffuser.
f80post
