is my intake charge pipe bad?
05-30-2015, 04:07 PM | #1 |
12
Rep 138
I am just getting into my injector and valve cover gasket job and I notice a little oil around one of the diverter valves but it is below it like on the charge pipe?
is this a common issue? I don't see any cracks, but if there is oil there, assuming there must be a small leak? I think for now I'm going to clean it and get my injectors and VCG done. is this common? is there a better part to replace it with? should I do the pipe and the Diverter valves? recommendation's? upgrades? the one in the left (towards the rear of the car) is the one in question as the front (right one) is clean |
05-30-2015, 04:48 PM | #2 |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
Blow-by is pretty common on N54 engines. Makes it into the intake pipe and sometimes all the way down to the FMIC. An OCC will help quite a bit.
05-30-2015, 06:07 PM | #3 |
533
Rep 2,872
It's blow by. Most N54's have quite a bit of it too, so don't get too worried!
An RB PCV, and OCC will help quite a bit, but unless you're seeing a significant amount of oil, don't be too concerned. FWIW, I can barely see any oil on the DV, so pull the chargepipe off an look inside to determine the actual oil blow by amount. Aside from that, a metal upgraded CP should be on your wish list! |
05-30-2015, 07:39 PM | #4 |
12
Rep 138
thanks, I do have a RB PCV to install also, along with a new breather hose,
I am not sure how the RB PCV goes in, I haven't looked at it much yet. |
06-01-2015, 04:32 PM | #5 | |
52
Rep 335
Use the o-ring from the stock cap if replacing with the RB cap, no o-ring required on the RB valve itself. |
06-01-2015, 04:51 PM | #6 |
3441
Rep 79,211
Most popular upgrades are Evolution Racewerks and VRSF Charge Pipes.
If you want to stick with Diverter Valves, most common is Forge but recently the turbo smarts are becoming popular. Can't go wrong with either, personal preference on looks and sound. Or you can go to a BOV like tial or HKS, again personal preference on sound or looks. HKS is the loudest option. Forge DV being the quietest next to TurboSmart Plumb Back. You may want to look into a BMS OCC, it will reduce that blow by and keep oil out of your charge pipe and intercooler. |
06-01-2015, 04:52 PM | #7 |
533
Rep 2,872
RB PCV install:
http://www.n54tech.com/forums/showpo...&postcount=190
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
