WG Rattle on cold start-Vacuum leak?
05-25-2015, 06:05 PM | #1 |
533
Rep 2,872
On cold starts, with the new firmware set to FUD-98, and even when it's not using the FUD settings (although not as bad), I have terrible rattle for about 15-20 seconds, then as it idles down, it goes away. Tapping the gas to high idle doesn't cause it to come back either when I'm just in neutral.
Would this be an indication of a vacuum leak? Maybe it rattles until vacuum has a chance to build up? I bought a vacuum gauge so I'll know soon enough if it's not holding vacuum, but thought I'd ask for some opinions.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
05-25-2015, 06:51 PM | #2 |
533
Rep 2,872
So I hooked a T into the right vacuum canister, brought the vacuum to "normal at idle" and shut the car off. After 10-15 minutes, the reading has dropped 1.5 in/hg. From 28in/hg to 26.5in/hg.
Indication of a vacuum leak it appears. |
05-25-2015, 07:04 PM | #4 | |
533
Rep 2,872
I thought idle vacuum at the canisters was supposed to be between 22-25in/hg?
05-25-2015, 07:13 PM | #5 |
648
Rep 2,013
You seem fine. 28 is great. Think it drops to 25 or so after a minute or more of idle. Mine pulls 25 at idle. They are supposed to be 22-25.and hissing sound is good.
Even after 15mins its 26.5? Wow
335i e92 TPC 19Ts
05-25-2015, 07:20 PM | #6 | |
533
Rep 2,872
Well, this is all coming up because of how bad my WG rattle is on startup for about 15-25 seconds. Which makes me think that once vacuum builds back up, the WG works normally, but until then, it has inconsistent vacuum. Thanks for checking that for me by the way!
05-25-2015, 07:26 PM | #8 | |
533
Rep 2,872
I really hope they test bad honestly, because i'd gladly slap new ones in to resolve some of the goofy issues I have at low throttle and rattle at idle like stated above, and on acceleration. Edit: I know how to do the solenoid test now. But it's dark outside so I'll test them suckers tomorrow!
05-25-2015, 07:53 PM | #10 |
352
Rep 2,050
My car has a wg rattle upon start up the same way u described. I always thought it was normal
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
05-25-2015, 07:59 PM | #11 | |
533
Rep 2,872
I really hope they're bad, this might help explain the inconsistent boost at WOT, it'll fluctuate +/- 1-2psi, the rattle on acceleration, etc. I bought all new Verocious Motorsports silicone vacuum line (13ft) to replace them all anyway, so hopefully this all gets sorted. The line I bought is rated for high temp too so it's a nice replacement for the old lines there now.
05-25-2015, 08:02 PM | #12 | |
648
Rep 2,013
335i e92 TPC 19Ts
05-25-2015, 08:09 PM | #13 |
533
Rep 2,872
Did you use BMW original? Or the other brand from ECS?
05-25-2015, 08:22 PM | #14 |
648
Rep 2,013
I got oem locally from getbmwparts. Its the same as Piersburg, which is cheaper and way to go.
335i e92 TPC 19Ts
05-26-2015, 06:22 PM | #15 |
533
Rep 2,872
Ok so I tested the firewall side solenoid. With menu 10 set to 5000RPM (full vacuum) I get 24in/hg. It should be ~30in/hg I believe is that correct?
Actually it looks like I'm only about 2in/hg under the example in the video on N54Tech. Not sure that it's enough to be concerned about. Last edited by 335NJ; 05-26-2015 at 06:48 PM.. |
05-26-2015, 07:18 PM | #16 | |
648
Rep 2,013
Take a look at this, if you havent and let me know. This is how i checked. At idle, at 3k etc.
335i e92 TPC 19Ts
05-26-2015, 07:32 PM | #17 | |
533
Rep 2,872
Video at the top, and yeah that's the chart I was basing my 30in/hg comment from. |
05-26-2015, 07:45 PM | #18 |
648
Rep 2,013
Its cool you can adjust the sloenoid vacuum. Video shows 25 or so max, so seems you are ok. How about the other one?
Mine are about 17, stock (also seen in the document). Firewall was pulling 5in less so replaced it. 30 is not at the solenoid.
335i e92 TPC 19Ts
05-26-2015, 08:40 PM | #19 | |
533
Rep 2,872
Thanks again! I'm going to replace all of the vacuum lines this weekend if I don't get time this week, but figured I'd try to get a good baseline. |
05-26-2015, 09:14 PM | #20 | |
648
Rep 2,013
335i e92 TPC 19Ts
