The Quest for Power (Stock Frame Turbo WR)
05-23-2015, 05:32 PM | #1 |
Reborn
84
Rep 1,217
Continuing from my previous thread, I decided to go back to the dyno to do a few tweaks. My setup is as follows:
The only change since last time is I ditched my customer rear inlet, replacing it with the VTT silicone hose. This fits much better and is actually shorter than the one I build by a good bit. I didn't have long on the dyno, so I upped the boost slights (holding 27.x) and added some mid range timing (10 degrees max now). I was very pleased with the results. Here are a few notes:
Attached are some dyno comparisons:
Here is the datalog of the last run: http://datazap.me/u/ghost/dyno-log-3...-29&zoom=30-81 Special thanks to Terry@BMS for the extensive support and parts, Fuel-it, and VTT for badass products and killer support. Last edited by The Ghost; 05-23-2015 at 05:53 PM.. |
05-23-2015, 06:23 PM | #2 |
Asleep
53
Rep 298
Great stuff, Ghost. Looking forward to further progress with your build.
It's nice to see folks like you lay down a path for others like me to follow!
2007 C6 Corvette... VaraRam intake, FAST 92 IM, AI ported stock heads, Cam Motion cam, TSP headers/x-pipe, Borla S-Types, C6Z differential - 425whp
2008 135i... VTT S2+, MOTIV PI, FBO - 582whp (sold) 1999 C5 Corvette... Blackwing intake, C5Z titanium exhaust - 344whp (sold) Others sold: W204 C350, E90 330i, W-body Monte Carlo SS, etc. |
05-24-2015, 12:14 AM | #3 | |
68
Rep 1,432
How does the car feel? How is the shift bog at that power level? What could make the difference compared to other 2+ turbo (clipped & 20t) upgrade cars such as VTT? PI with 100% E85? Tuning? Custom front inlet?.... |
05-24-2015, 12:28 AM | #4 | |
Reborn
84
Rep 1,217
When I got on the dyno last time, I started at 550whp and ended at 639whp. Today, the first run was at 645whp. And I ended at 681whp through tuning (to include boost). I haven't gone WOT since the dyno as it is raining here. At 640whp levels, I have no shift bog (fixed that in the flash) but I did get timing corrections, which I mostly removed via Vanos. Last edited by The Ghost; 05-24-2015 at 10:06 AM.. |
05-24-2015, 02:19 AM | #5 |
1978
Rep 345
05-24-2015, 09:23 AM | #7 | |
136
Rep 1,202
First:The Ghost results against our own Stage 2+ results Second: Stage 2+ Vs VM 6465 Third: Stage 2+ Vs Motiv 750 |
05-24-2015, 09:37 AM | #8 |
9
Rep 75
It just keeps getting better and better! Congratulations on the new numbers.
RIP10' A/W M-Sport-JB4-E85/93,50/50-BMS DCI-AR DP'S-Balck Kidney Grills-muffler delete-mm6 mesh18x8.5/9.5-Conti DWS 235/40 18, 265/35 18.
10'e90 a/w SportPackage-mhd e40 map- a/r dp's-vrsf charge pipe and tial blow off valve 95 civic-k24 block-k20 head-12.5:1 c/r pistons-drag cartel stg4 cams-ported rbc mani-q45 90mm tb-ssr headers- 3" exhaust, 300+whp, 2000 lbs. |
05-24-2015, 10:12 AM | #9 |
Reborn
84
Rep 1,217
My car has never had bad shift bog, likely due to the current state of our flash maps (Cobb, community versions), however once I switched from flash-only to JB, I got bog periodically. One of the good tuners here suggested I change the "Torque Eff Divisor (Fuel)" table to have stock values to cure this. I changed them and haven't had a single bog since. YMMV
On an unrelated note, I switched to MHD for flashing a few days prior to this dyno session. Last edited by The Ghost; 05-24-2015 at 11:07 AM.. |
05-24-2015, 01:49 PM | #10 | |
DIYER
614
Rep 5,521
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
05-24-2015, 03:55 PM | #11 |
DIYER
614
Rep 5,521
Here is a good comparison
05-24-2015, 04:21 PM | #12 |
136
Rep 1,202
Why would I compare one kit at 27 psi to another kit at 27 psi. Hmmmmm geeeeee I wonder..... It shows very clearly at the same boost levels the stock twins clearly out perform the singles, and are much more fun to drive. If you want to run 30 psi+ then a single would be a better choice. Even with another 5psi the single isn't pulling away too much. Terry is already talking about pulling his single and putting a set of these on. Obviously they are working very well. Also I think you must have forgot, but the 6465 graph I posted, that was all Payam could get out of the turbo for whatever reason, which is why he started trying different turbos. Please show me a 6465 graph at 38 psi. Let me know when you find it.
05-24-2015, 05:52 PM | #13 | |
DIYER
614
Rep 5,521
I am not saying you didn't get great results Tony, just want a fair comparison, you found the lowest VM dyno you could find and compared it...
05-24-2015, 06:14 PM | #14 | |
Reborn
84
Rep 1,217
The fastest cars will no doubt not have stock frames on them. It is good that we have options and stock frame are not limited to 500whp as they were just 12 months ago. What I can say is I don't believe most ST owners are making 700+whp, just as there are only a handful of stock frame cars who have posted over 600whp. |
05-24-2015, 06:19 PM | #15 | |
DIYER
614
Rep 5,521
I was only having a issue with the comparison, I said nothing negative about your results because there is nothing negative to say. Edit: reread your post, disregard the comment about who's fastest lol!
05-24-2015, 06:30 PM | #16 | |
Reborn
84
Rep 1,217
I think you should re-read my whole last post and just smile. I said it is good that stock frames are no longer limited to 500 (I said nothing about what you know). |
05-24-2015, 06:38 PM | #17 |
DIYER
614
Rep 5,521
You have a bigger bottle neck, shift bog.
05-25-2015, 09:58 AM | #18 |
136
Rep 1,202
Man for a guy who was super friendly about a month ago, you sure are sounding a lot like a hater these days Rob. Looks like you are sipping the RB Kool-Aid again which is fine. My comparison was the motiv turbo kit at 23, and 27 psi, so yes the SAME boost level making less power everywhere. The other was a 6465 at 27 psi, making about the same power up top, but less down low. That you have a problem with comparing two different systems at the same boost makes little to no sense. Great, so the singles can turn up the boost, I had no problem holding 30 psi to redline on these turbos during street testing, so we there is more room in these as well. I know these results do not sit well with a lot of single owners that shelled out 6-8K for a kit, and are making less power, and have a car that is not as fun to drive, but that is just the way the stock frames are going these days. Cheers
05-25-2015, 10:27 AM | #19 | |
DIYER
614
Rep 5,521
Shift bog = known issue The results don't bother me, I think its great but your comparing your setup to the weakest dyno, thats what I had issue with, why can't you compare it to the PTE that most are running with the VM KIT? Also, what are you talking about not fun to drive? My Motiv has no lag, have many that can vogue. Well actually not my Motiv anymore. Less power? Can you read the dyno graph I posted? VM = 757WHP VTT = 681whp VM = 676 torque VTT = 620 Where is there less power? The 6466 can make well over 800whp, my buddy "josh Putoff" Mr-MR2guy made 861whp @ 36 psi and is turning it up to 40psi for over 900whp.....please show me some VTT products with these numbers please. Algo let's not also forget the single guys post a bit more money but they last because they're not maxed out all the time. I am not hating, just dont like the fact your trying to make it look line something its not man, you knew full well there was a higher dyno but decided to post the weakest one to make your product look better. You don't have to do that, stock frame with 681whp is impressive.
05-25-2015, 10:58 AM | #20 |
58
Rep 319
Wow got to love it, bought a 8 year old Beamer and people are still raising the bar and developing new products. Got to love the n54 and it's capabilies and options what a great platform and look forward to moding to futher modding it over the years. I am so glad this car is living on and people are still passionate about it.
05-25-2015, 01:42 PM | #21 | |
135
Rep 1,075
Congrats on the numbers Ghost. Once I get my car back together and tuned, I will be headed to the dyno with my RB EVO powered automatic. Based on what we've seen on low boost, I'll be shocked if I'm not over 700rwhp/tq.... |
05-25-2015, 01:43 PM | #22 | |
Rep 538
If you want to be fair we should look at one of the best performing single turbo kits at 26psi. I had to dig back two years ago to find it. 26 psi with a PTE6466, it made 738RWHP. Keep in mind this was two years ago when stacked flashes were just getting started and torque was intentionally kept low to keep the engine safe. I think you know what a 6466 is capable of with modern tuning and modern fueling.
http://www.e90post.com/forums/showth...o#post14422354 It's hard to find dyno charts at 25-28psi from single turbo owners simply because they don't stop there. Why buy a big single and only run 25psi? This- Quote:
