Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Oil Cooler Hose - Oil leak help.
      05-23-2015, 04:42 PM   #1
twosickz
51
Drives: 335i single turbo
Any idea why I keep getting this oil leak around the oil cooler lines after performing the oil filter housing gasket DIY?
I've replaced both oil cooler line o rings with brand new oem ones. Am I over tightening this bolt?
      11-26-2017, 07:51 AM   #2
pagedownhere
Drives: 07 335i
Any luck on this? I replaced my ofhg and reused the 2 o-rings you mention as I didnt have new ones on hand. It started leaking so i relaced them with new ones from the dealer. Seems to still leak from those 2 o-rings. I tightened it pretty damn good. Any suggestions?
Thanks!!
      11-26-2017, 12:59 PM   #3
Stroker1
35
Drives: 07 335 cp dci, ***dp's, jb4
Looks like quite alot of corrosion in area. My guess is the bore and fitting grooves weren't cleaned well enough prior to assenbly I would clean bores and oring grooves on fittings, lube the orings before assembly and torque to specs.
      11-27-2017, 10:20 AM   #4
twosickz
51
Thanks!!
After weeks & weeks, I figured it out. It ended up being this cap gasket, that is highlighted in yellow, causing the leak.
I removed the 2 screws holding the cap and put silicone gasket maker and it hasn't leaked since.
      11-27-2017, 12:39 PM   #5
pagedownhere
Drives: 07 335i
twosickz Thanks! I will check that out! I was going to put some black RTV gasket maker on the 2 oil cooler connections as well. It wouldn't hurt to put it on all 3 spots would it?
      11-27-2017, 12:55 PM   #6
twosickz
51
Don't put any gasket maker in the o ring connections. Just the cap and very little aswell.
      11-28-2017, 08:44 AM   #7
Jklad
Jklad's Avatar
Drives: 2007 335i Coupe
Thanks!!
Is it possible to purchase the gasket for that cap seperately? I've looked all over realoem and can't find it listed. the aftermarket oil cooler tstat vendors do not sell it either. Mine's been seeping oil for a bit.
2007 E92 335i MT
      11-28-2017, 10:14 AM   #8
twosickz
51
Not sure. I would ask your local bmw parts dept & provide vin.
      01-10-2018, 06:54 AM   #9
pagedownhere
Drives: 07 335i
By the way twosickz is spot on with this! Popped off the oil cooler stat cover, added a small amount of black gasket maker and havent had an issue since!
thanks!
      01-10-2018, 08:28 AM   #10
feuer
feuer's Avatar
Drives: wife crazy!
No gasket replacement. No thermostat replacement either. Silicone would be only option.
Appreciate 2
Jklad421.00
      11-12-2019, 10:17 AM   #11
Tallicia
Tallicia's Avatar
Drives: X6 and 1 series
2013 X6  [0.00]
2011 BMW 135i M Spo ...  [0.00]
This is going to become a much much more important thing to know as these incredible motors get into their truly appreciated years!
I've been chasing this leak all year. I see aftermarket a $50 replacement with seal for the thermostat cover.
Thanks for confirming my suspicions. I replace the OFH gaskets twice, and just replaced o-rings a second time. This is the only other possible place and it sure does it in a very hidden way. Grrr.
It's a real real shame there isn't a $10 gasket that can be purchased to replace this!
      02-12-2020, 05:15 PM   #12
EconIsLyfe
Drives: 2008 335i 6MT
FTP has a thermostat cover kit for $45 on ECS Tuning. Comes with the cover, new bolts, and a new gasket.
https://www.ecstuning.com/b-ftp-motorsport-parts/ftp-thermostat-cover-kit/sg84006-ct~ftp/?gclid=CjwKCAiA4Y7yBRB8EiwADV1haeOOmXZks9SU5dyBK5s QiPPq8UUtZ4eVT3HmKyZ2hw27k6iLMOacXBoCXu4QAvD_BwE
feuer4275.50
      02-12-2020, 06:44 PM   #13
rgfinn76
47
Drives: 2008 335i Sport Coupe
What is the correct torque on the 13mm bolt holding the H plate and oil cooler lines in place?? I looked all over and cannot find the proper torque.
I just got don't replace the OFHG and see the same little oil residue leaking as in the picture above.
      02-13-2020, 05:31 AM   #14
EconIsLyfe
The oil lines will leak right there even with new O-rings because the plate that holds them down bends (like in the picture if you look closely). It can be heated and bent back, replaced for $180 each line, or converted to 10AN (this is the option I went with)
      02-15-2020, 11:06 AM   #15
rgfinn76
47
I replaced the O rings again this morning. I noticed it’s leaking from damn cover and not the cooler lines.
Guess I’ll get the placement kit from ECS.
      06-12-2020, 07:46 AM   #16
BarraCuda
Drives: 86-325ic-5MT, 07-335i M 6MT
EconIsLyfe, thank you! Seems like the best option on this (I hate doing a job more than once) can you give a quick step by step on the conversion for us, I found some 10an fittings, would you have a parts list?
      09-21-2020, 08:37 PM   #17
jin
New Zealand
74
Drives: 2007 E90 335i
I think I have this problem. What is the adapter plate you used for the oil lines? Can you use the adapter with the stock oil lines?
      11-08-2021, 06:10 PM   #18
chance91
Drives: 2011 Bmw 335d
Just wanted to give back here. Came up in a search and found the solution for that cover.
An oring sized
37 mm ID, 43 mm OD, 3 mm Width
Works perfectly. Used in a few of my cars now.
https://www.amazon.com/gp/aw/d/B005RUTCYI/ref=ppx_yo_mob_b_inactive_ship_o0_img?ie=UTF8&psc= 1
Appreciate 2
feuer4275.50
      11-09-2021, 01:05 PM   #19
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
An oring sized
https://www.amazon.com/gp/aw/d/B005R...?ie=UTF8&psc=1
Link to o-ring thread:
Make sure you get the Viton material o-ring.
Appreciate 2
feuer4275.50
