2008 335xi won't start after replacing mosfets on MSD80 DME
05-22-2015, 08:44 AM | #1 |
Rep 28
I got the 30bb code a couple weeks ago, tested the mosfets to find the one for injector #5 was bad. I had all six replaced and put the DME back in to find that the car will only crank but doesn't start. I'm getting these codes.
Is the DME fried? |
05-22-2015, 06:27 PM | #4 |
Rep 28
I have in a sense I suppose. I first reinstalled the DME with the JB4. When it didn't start I tried changing the map but I couldn't access the menu on the gauge cluster. So guessing the DME is not getting any power.
I then tried installing DME without JB4 which made no difference. |
05-26-2015, 01:10 PM | #7 |
Macgyver
208
Rep 942
Did you replace the mosfets by yourself or had someone do it? I'm curious as to whether the copper underneath was ripped off. I so then no power would get to them.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
05-27-2015, 08:22 AM | #9 | |
62
Rep 307
05-27-2015, 09:14 AM | #10 | ||
Rep 28
05-27-2015, 09:55 AM | #11 |
Rep 8
Dam man..same thing happend to me...I replaces 2 mofsets and recently had the same codes..2acb I found the dme master relay...it's a blue relay inside the dme box on the same side as the little fuses box in there also. I'm going to replace today and see if my car works...keeps shutting off on me.I have a friend that is very very good with dme mofsets and coding etc. Gregory latchman..out of queens I'd hit him up if I were you +13475283962
05-27-2015, 01:35 PM | #12 | ||
Rep 28
05-27-2015, 02:37 PM | #13 |
Rep 8
05-28-2015, 10:31 AM | #15 | |
Rep 28
03-17-2016, 10:37 PM | #20 | |
Rep 28
09-27-2016, 12:05 AM | #21 |
Rep 8
