Time for new turbos?
05-20-2015, 06:54 PM | #1 |
Rep 13
i have an 08 335i MT that's at 143k (lots of highway road trips and commutes) and a few month back I started throwing 30FF codes for low boost pressure. After running checks for leaks and replacing a stock charge pipe that had a small leak where it met the diverter valve(which was also replaced) and all the vacuum lines I am still going into limp mode at the high end of second gear or if I try to accelerate from about 2500 rpm to 3500 in 4th. I recently noticed I'm starting to get some of the turbo whine/siren noise especially on cold starts. So my question is at this point does it look like it's time for turbo replacement? Apart from what's listed above the car is in great shape with only normal issues like the water pump and O2 sensors. Only engine mod I have is a Stett CAI and it has never been tuned.
Edit: I've also tested the pressure converters (boost solenoids) and they are functioning normally |
05-20-2015, 11:29 PM | #2 |
BimmerPost Supporting Vendor
24199
Rep 190,807
If you have no leaks and the boost solenoids are good then yea it is time for new turbos.
05-21-2015, 04:08 AM | #4 |
Rep 13
http://www.n54tech.com/forums/showthread.php?t=13114
Check out that link, the parts to test the solenoid were about $30 total from advanced auto parts. Unless someone has any other info to add thinking it may not be turbo related are there any N54 turbo replacement DIY's posted anywhere? I have the Bentley manual but I'm a little unclear about lifting the front end of the engine up. I do believe that is part of the process? |
05-21-2015, 05:50 AM | #5 | |
648
Rep 2,013
At idle after a min or so, the gage should read -14 to -18 in hg. Same with the other solenoid. They can also be tested w no load at 3k rpm. Vacuum numbers are 17 -20in.
335i e92 TPC 19Ts
05-21-2015, 07:52 AM | #6 |
Driving cars and riding bikes really fast
285
Rep 1,002
Turbos
Time for new RBs I think!
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
