Head unit & USB retrofit parts from M3 E92 to use on non-M E93
05-20-2015, 02:13 AM | #1 |
29
Rep 83
Not sure if this has been discussed before, but I've come across two cars that are being wrecked for parts and wondered if I can salvage part to do some retrofits on my E93 325i, with I-Drive and Base audio system.
First question: The M3 E92 I mentioned has the HiFi head-unit and USB connection, which I wondered if I can use on my car. I've asked the seller to see if the car has had an IDrive as well or not, will that make a difference? as I said my E93 is Base Audio with Professional Nav but no USB Second Question: There is a F30 320i being wrecked as well with IDrive, will I be able to salvage any parts to do a NBT retrofit? I know I'd have to code any of the above for them to work but my main question is around compatibility with E93 |
05-20-2015, 02:41 AM | #2 |
456
Rep 2,749
if the first car have USB socket in armrest you can remove module socket and wiring.
Last one will be a bit complicated though.
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
05-20-2015, 03:53 AM | #3 | |
29
Rep 83
Not sure but as mine is a 2007 model don't think just the usb/aux port and wiring would do the job. Any thoughts? |
06-09-2015, 04:15 AM | #4 |
456
Rep 2,749
you need to remove MULF2HIGH, wiring and USB socket from wrecked M3
if M3 is 2011MY and do not have Idrive there may be Professional Radio headunit with intergrated USB
