05-18-2015, 11:41 PM | #1 |
43
Rep 100
Misread the coding instructions...Drivetrain: Check soon error...
Hey guys, I'm kind of terrified right now. I read and reread the instructions but my finger slipped and I tapped Code on the ECU tab and after it finished my car came up with the "Drivetrain: Check soon" error. It won't go away after a restart (waited a few seconds to restart). I didn't change anything, the only thing I did was to read one of the CAFD files. I'm terrified and I'm taking it in tomorrow. Any one experience this? Anyone know what it could be?
05-19-2015, 06:18 AM | #2 |
1381
Rep 3,834
If you backed up your FA and SVT files before you coded, just reload them and you should be fine. If that doesn't work, the dealer can reload your software. No worries as long as you didn't click on the "Code Default Value" button.
Daily: G12 750 MSPORT Weekend Car: E90 M3
05-19-2015, 09:35 PM | #3 | |
10413
Rep 40,664
Drives: 2018 Alpina B6 650ix GC
You must inject new CAFD into DME and VO Code it now, and motor must NOT be running when you do it..
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
420Coupe222.50 |
05-21-2015, 02:11 AM | #4 | |
43
Rep 100
05-21-2015, 04:59 AM | #5 | |
10413
Rep 40,664
From the Instructions: *NOTE: A continuous power source of at least 12.6 Volts is needed. Failure to maintain proper voltage can lead to corruption of ECU Data. As such, ideally the car is connected to an external charger. In lieu of using an external charger, the car can instead be coded with the engine running in order to maintain proper voltage, which is acceptable for coding all ECU's EXCEPT the DME (Digital Motor Electronics) ECU or DDE (Digital Diesel Electronics) ECU. The DME/DDE are typically not coded anyway, so this ECU limitation is generally not an issue. So to fix it, with the Motor OFF, perform the following: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on DME => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on DME (the ECU itself not the underlying CAFD) => Select CODE.
05-21-2015, 04:27 PM | #7 |
68
Rep 224
A slip of the finger could happen to anyone.. it's nice to have balls, learn something new, and not be dependent on others.
Coding is a matter of simply following directions. It's hardly rocket science. Good luck, OP! |
05-22-2015, 08:56 AM | #9 |
1381
Rep 3,834
shawnsheridan Maybe there should be a "Lite" software w/o CODE ECU and Default Code Values buttons.
05-22-2015, 08:59 AM | #10 |
10413
Rep 40,664
A way to Disable Code Default Values would certainly be welcome.
06-03-2016, 11:34 AM | #11 | |
Rep 28
Drives: 428iX M- SPORT
Error when coding DME2
https://drive.google.com/open?id=0B_...HV2RVZhX2RXSEE
06-03-2016, 11:43 AM | #12 | |
10413
Rep 40,664
Did you turn car off afterwards, and then restart it and check DME CAFD to see if it was fixed or still missing / corrupt?
06-03-2016, 12:37 PM | #13 |
687
Rep 2,770
Just FYI to folks, there is a thread going on where we are working out a good external PSU that can provide enough juice to power the car. It was developed for flashing operations but I am planning on using while coding primarily. It should allow you to turn the car on and leave the engine off while coding and not run down the battery at all.
http://f80.bimmerpost.com/forums/sho....php?t=1262137
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
10-19-2022, 01:53 AM | #14 | |
Rep 3
I have the same issue after trying to code Drivetrain malfunction message and fuel supply Select the CAFD from latest I-Level shown What's I-Level? Where it is please? |
10-19-2022, 10:05 AM | #15 |
10413
Rep 40,664
When you click on "Detect CAF for SWE", you are shown a list of CAFD files linked to I-Levels. Just pick newest (bottom) one.
