ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      02-08-2008, 11:15 AM   #1
Evoking
95
Drives: Z4M Coupe
Aggressive M3 Fitment work on Z4M?
What is the lowest offset at Z4M? For example can an aggressive M3 Fitment work on Z4M? Something like 19x8.5 +32 offset and 19x10 + 20...
      02-08-2008, 12:52 PM   #2
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
10 inch rears with a 20mm offset is too close. I would go with 25mm offset. I mounted a set of 18x10 ET25 with 285/30-18 cup tires and they rubbed slightly inside the well on the plastic. I had to go with 265/35-18's instead. A 20mm offset I am affraid might be really close. It would probably work, but you would likely have to cut away some plastic on the inside of the wheel well.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      02-08-2008, 03:48 PM   #3
Evoking
95
Drives: Z4M Coupe
Thanks for the feedback. Was going for extra deep lip. The tires would be 275/30 so I'm hoping they would fit.
Anybody else?
      02-09-2008, 10:05 PM   #4
VoiD
14
Drives: Z4MC >>> C63
2007 Z4 M Coupe  [0.00]
I'm running 10.5" ET25 in the back and have no problem with 275/30
      02-09-2008, 11:49 PM   #5
Evoking
95
Drives: Z4M Coupe
So how does 10.5 with ET25 compare to 10.0" ET20? Which would stick out further?
      02-10-2008, 12:09 AM   #6
VoiD
14
try the offset calculator: http://www.1010tires.com/WheelOffsetCalculator.asp
it says you get 11mm more inner clearance and 1mm on the outer side with a 10" ET20 compared to 10.5" ET25
zpost
