Software Updated?
05-15-2015, 02:14 PM | #1 |
Driving cars and riding bikes really fast
285
Rep 1,002
Software Updated?
Hello Everyone,
I test drove a 2009 335i with the 6-speed. Looking to purchase the car because it's basically flawless! The only issue I noticed was a slight lack of power down low in the RPMs. My previous 2008 335i felt much faster and had no performance mods. Question: Is it possible to tell if the car has the upgraded software?? or in other words the crap BMW's fix to stop WG rattle etc?
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
05-15-2015, 02:54 PM | #3 |
285
Rep 1,002
Not sure! It's a 3 owner car and the carfax looked good with nothing changed other than spark plugs at 40k miles and tires. Maybe its super clogged?
05-15-2015, 03:22 PM | #4 |
109
Rep 1,062
If your buying from the stealer it probably has, try and look at service history. Or you can take it to a stealer and they can tell you.
I think if you hold the DSC button if a picture of a car losing traction comes up on the odometer area that means it's been updated. Not positive though.
Sideways is the way of life.
05-15-2015, 04:05 PM | #5 |
533
Rep 2,872
Well depending on the current mileage, it could be past due for plugs/walnut blast, etc. a good tune-up of that nature could free up some lost power.
05-15-2015, 04:43 PM | #6 |
31
Rep 122
Was you 08 a manual trans. When I first started driving my 09 335 6 speed I thought I felt a little slow down low but after a few months I figure my rpms were just too low for speedy accelerations.
05-15-2015, 05:13 PM | #7 |
91
Rep 817
I'm not sure if my car ever had the BMW software "upgrade" but i'm now running a cobb tune so does that totally cancel out any bmw software changes so I'm not affected by it anymore if it was done to my car?
05-16-2015, 06:44 AM | #8 |
285
Rep 1,002
Yeah my last car was the 6-speed. I'm thinking plugs and wires as well. Does a tuner cancel that BMW software shit or over ride it? I don't have the money for a tuner, walnut blast, and plugs yet. I was quoted $700 for the intake cleaning alone in Indianapolis
05-16-2015, 03:06 PM | #9 | |
648
Rep 2,013
So must be fine! I just got back from the dealer this morning upgraded to latest software and they specifically did the wastegate valve conversion. so ask me!
335i e92 TPC 19Ts
05-18-2015, 08:02 AM | #10 |
285
Rep 1,002
Did you go into the dealership for WG rattle issues? How does the car drive now since you got it back?
05-18-2015, 11:10 AM | #11 | |
648
Rep 2,013
The bmw tech was great, updated the software and did the waste gate conversion, as they call it. This brings the wg vacuum levels to values before the rattle fix. They now measure 18in Hg after 1min of idle. This is great, the lag is gone and very responsive. Again, 2009 model year this is not applicable.
335i e92 TPC 19Ts
05-18-2015, 12:21 PM | #12 | |
285
Rep 1,002
05-18-2015, 12:54 PM | #13 | |
109
Rep 1,062
05-18-2015, 01:12 PM | #14 | |
285
Rep 1,002
05-18-2015, 01:33 PM | #15 | |
648
Rep 2,013
All software updates have the laggy waste gate setting by default. The tech has to specifically open a dialog box and check waste gate conversion. This will result in the higher vacuum setting at idle and deceleration (i.e. not wide open waste gate). To measure the vacuum is the best way to find. I have before and after numbers. Good news once the waste gate conversion is done, future updates will not erase it (because its a separate setting).
335i e92 TPC 19Ts
05-18-2015, 01:40 PM | #16 | |
648
Rep 2,013
In the laggy setting the vacuum is almost 0 at idle/deceleration and the vacuum increases only around 3k rpm. This is quite a lag. With waste gate conversion there is 18in hg at idle/deceleration (means wg is semi closed ready for instant action).
335i e92 TPC 19Ts
05-18-2015, 01:52 PM | #17 | |
285
Rep 1,002
05-18-2015, 02:27 PM | #18 |
109
Rep 1,062
By any chance would you know what software you were on before and what software you are on now? BMW introduced new software which had that option enabled by default, and it was also removed from ISTA/P programing menus... I should know, I downloaded 60GB of it at 500KB/s only to find the option wasn't there.
But if I can reduce my lag further, fuck it I will go to BMW of Catonsville.
05-18-2015, 03:09 PM | #19 | |
648
Rep 2,013
335i e92 TPC 19Ts
05-18-2015, 09:27 PM | #20 | |
Stupid Idiot
134
Rep 827
If you have a pre-9/07 car, then the "wastegate valve conversion" is for you. And just as an FYI.... aftermarket flash tuners like Cobb don't overwrite this logic. I did this procedure on my own car (1/07 build) since my turbos were in great shape and I wanted to get rid of the added lag that BMW gave the previous owner. I uninstalled the AP, programmed the car with ISTA/P (including the wastegate valve conversion), then re-installed the AP.
05-19-2015, 11:00 AM | #21 | |
285
Rep 1,002
