Improve sound for sws-8x ?
05-09-2015, 07:24 PM | #1 |
58
Rep 241
I did a full aftermarket radio, 5.25'' morel virtus speaker upgrade and
I installed a pair of sws-8x to a jl xd700/5. both speakers and subs are crossed at 80hz 24db. Morel hit too low on 12db at 80hz and i'm afraid to burn them. 50% gain on speakers, 70% gain on subs The sws-8x hit amazingly hard and deep on low notes, but on most songs they are barely audible, even on high volume. Also when i go past 50-60% volume the subs start distorting and seem much less audible. I had high hopes for the sws-8x, but they fell short. Is there any way to improve the sound? I put some gtmat sound deadening inside the enclosure, cut the carpet around the sub. put 2 nuts on each bolt between carpet and grill so the grill is raised a bit. No rattles of any kind are present. I bought some "Sonic Barrier" acoustic foam and will try to improve the upper notes. I understand that the poly-fill is for lower notes, right? So i should not need it. There is plenty of low notes with sws-8x but upper notes fall off terribly. Did anyone try to seal the sub enclosure? Would the enclosure's volume be enough for the sub? |
05-09-2015, 10:57 PM | #3 | |
58
Rep 241
https://mega.co.nz/#F!5JYRRKwQ!J99Nkp8YgsjPwrWd48Y_vA I don't have a sub in the trunk. |
05-10-2015, 05:24 AM | #4 |
255
Rep 2,547
you may want to try doing a raising your low pass frequency on the underseats, it is ok for them to cross with the door speakers. try moving them up slowly to 150 as you listen to music see if they start to become audible.
05-10-2015, 05:39 AM | #5 |
730
Rep 1,815
With my MS-8 install in my e87 I found that the best crossover frequency between the underseats and the mid range was around 200hz.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
05-10-2015, 01:41 PM | #6 |
300
Rep 3,969
Did you try reversing polarity of the Earthquakes?
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-10-2015, 04:12 PM | #7 | |
58
Rep 241
I don't have any issues with the 80hz+ because Morel Virtus 502 5.25'' play more midbass than i ever wanted. The issue i have is with the subs around 50 to 80hz. The funny thing is that the morel speakers are much louder than the subs at 1/3 the wattage(50w) given to them compared to the subs(150w). I wish the sound was more balanced. The subs are much louder only if they play 30 to 50hz notes. This is definitely not a sub issue, but the enclosure's and the inside air not circulating right for the sub parameters. |
05-10-2015, 04:15 PM | #8 |
58
Rep 241
I'll give it a try. Is reversing the polarity and turning on reverb on the radio the same thing?
BTW I see that you have idmax15, how do those compare to the idmax12? Idmax12 was one of my favorite sub, unfortunately they could not take more than 650w in a sealed box. Fi q12 sounded just as good with much more power handling. I wish i still had it. |
05-10-2015, 04:30 PM | #9 |
58
Rep 241
I'll give it a try. If nothing works, i'll seal the sub enclosures. The subs seem to play like they are in free air.
05-10-2015, 06:09 PM | #10 | |
300
Rep 3,969
I've never heard the IDMax 12, but the 15 has been my best subwoofer ever.
05-10-2015, 06:19 PM | #11 | |
300
Rep 3,969
05-11-2015, 12:23 AM | #12 | |
730
Rep 1,815
05-11-2015, 08:27 AM | #13 | |
300
Rep 3,969
The reason why most people have had best luck with a crossover between 200 and 300Hz is simply due to the midrange's inability to play anywhere below that. Most 4" mids fall into that category. But in that case you will have the imaging pulling down. Some people deny that, simply due to the fact that they have not experienced the sound of a door mid playing 100Hz with authority. Once you hear that, there simply is no going back.
05-11-2015, 08:54 AM | #14 | |
730
Rep 1,815
05-11-2015, 09:18 AM | #15 | |
300
Rep 3,969
Think about this...if the midrange is capable of playing 100Hz with authority (and as loud as you'd ever want it to play), why would you NOT have them play that frequency? I have 10" harcore, dedicated midbass drivers under the seats. If I had them in the doors, or in the kicks (if that were physically possible), I would probably have them playing higher. However, I have tried numerous different crossovers with these underseats, and the lower I go, the better the imaging gets. Right now I have it set at 100Hz, because the JBL door mids can take it all day. Any musical notes or voices that dip into the bass region, like deep voices (e.g. Johnny Cash), or guitar strings, or kick drums, are firmly anchored on the dashboard where they belong. When I had the x-over at 160Hz - I was using different mids that maxed out at 160 - the image got stretched height-wise, and I could hear the underseats play part of the notes, which at the time was "normal" for me. Now that I have the JBLs, the difference is night and day! What a difference 60Hz makes! Of course, the higher you go with the crossover, the more the underseats play. At around 150 - 250Hz, there is a nasty floorboard resonance that gets added into the mix and makes things even worse. And believe me when I tell you, there is no amount of EQ or TA, or whatever you can apply to get rid of that, and to firmly plant the imaging of the entire frequency spectrum onto the dash. The only way you do that is with proper crossover point selection (and of course having the drivers that are capable of playing in those frequency ranges).
05-11-2015, 09:51 AM | #17 | |
730
Rep 1,815
05-11-2015, 05:23 PM | #18 | ||
300
Rep 3,969
05-11-2015, 05:45 PM | #19 |
58
Rep 241
thank you so much for advice everyone, very helpful.
I listened more carefully to the audio today and i figured it out. Some beats in music were bouncing from speaker to subwoofers to speakers and that was causing some disappointment. Speakers at 80hz 24db and subs at 80hz 24db were not blending right. Getting subs to 80hz 12db solved the problem. One small issue i still have is that the subs sound a little boomy past 50% volume, like an echo right after each note. Hopefully will solve that with some acoustic foam. |
05-11-2015, 06:50 PM | #20 | |
300
Rep 3,969
05-12-2015, 01:54 PM | #22 |
58
Rep 241
thanks kaigoss69, i'll give it a try.
here is my installation qtvivi http://www.e90post.com/forums/showthread.php?t=1126014 |
