Base Stereo Upgrade - Harness question
05-09-2015, 12:29 PM | #1 |
Rep 8
Adding a couple of amps to my base stereo system (2010 e90). I've purchase 2 metra harnesses so I can run the wiring to the trunk and back.
My question is that the metra harnesses dont seem to have all the connections they should. Has anyone got pics or dealt with this? I couldn't find anything on the search, also cant find a wiring diagram for the base system (only hifi and logic 7). Additional details Speaker inputs to AudioControl LC7i, from there to a 2 channel amp (under seats) and a 4 channel amp (doors and rear). Thanks |
05-10-2015, 12:09 PM | #3 |
tends to get irritable
202
Rep 798
A harness from technic would be the best/most efficient approach.
An LC7i or any other summing device has zero advantage for Base (stereo) as there is nothing to sum and it does not correct the nasty OE eq curve. Correcting that would come in the way of (typically) a DSP of choice.
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
05-11-2015, 04:09 PM | #4 | |
Rep 8
05-11-2015, 05:28 PM | #6 |
1915
Rep 13,107
If yuu want to do it without cutting wires
If you want to do it without cutting wires
The Technic Harness is the best way . If you want to duplicate it you would need some expensive crimpers and connectors. Although connecting a stereo is not that different than it was 14 years ago the complexity of the cars and the way the stereo is integrated with the rest of the car can be and usually is. Speakers that fit in these is limited due to the thin doors and there is and eq problem with the base stereo that requires a frequency flattening device or processor to correct, unless you can find away to recode the radio or idrive for low level flat outputs . And what 6speed said about the LCI. A basic upgrade of the base system looks like what is in the following link and explains what is going on with the eq problem http://www.e90post.com/forums/attach...1&d=1411521234 BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=343673 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://www.e90post.com/forums/attach...1&d=1209780865 electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...4&d=1278871872 Install procedures http://www.e90post.com/forums/showth...ght=door+wires http://www.e90post.com/forums/showthread.php?t=911595 http://www.e90post.com/forums/showpo...9&postcount=19 http://www.e90post.com/forums/showthread.php?t=571803 http://www.e90post.com/forums/showth...ht=amp+install http://www.bimmerdiy.com/dir/e90 http://www.e90post.com/forums/showth...DIY+door+panel http://www.e90post.com/forums/showthread.php?t=553388 http://www.e90post.com/forums/showth...hlight=speaker Last edited by ctuna; 05-11-2015 at 05:42 PM.. |
05-11-2015, 06:12 PM | #7 | |
Rep 8
I've also found the pin-out for the factory harness so I should be able to get everything else connected now (eq problems aside). I can handle "complex" as long as I can find all the information I need. This forum has been a great resource, and I appreciate all the help! |
05-11-2015, 09:03 PM | #8 |
202
Rep 798
The LCi, in blunt terms is useless. It won't doing anything for Base and nothing is needed for HiFi. The wiring is very straightforward and the only obstacle is the huge, smiley face, eq applied.
05-11-2015, 09:11 PM | #9 | |
Rep 8
"Many factory systems actually turn the bass down as you increase the volume, because the cheap factory speakers can't take it, subsequently removing much of your music's power and punch. AudioControl developed a patent pending AccuBASS™ circuit that restores the bass the factory radio erased, giving you much fuller and more enjoyable sound. The AccuBASS is applied to the subwoofer output channel, so your sub amp can have the entire, restored signal to work with." Don't I just need something that will take my line level inputs and restore the bass like this? |
05-11-2015, 09:16 PM | #10 | |
202
Rep 798
First you need to understand the eq curve. Try this image: http://en.wikipedia.org/wiki/Smiley_...ey_Face_EQ.png Does it appear that the bass or bottom end are lacking or need restoration ? Negative. You need to flatten that curve, something that the LCi does Not do, at all.
05-11-2015, 09:30 PM | #11 | ||
62
Rep 307
05-11-2015, 10:51 PM | #12 |
1915
Rep 13,107
No L7 no need for using the L7 amp as a preamp
which is kind of an inelegant solution anyway. |
