Will the e93 LCI side skirt fit a pre lci
05-08-2015, 09:18 PM | #1 |
508
Rep 764
I have a 2007 e93 and the right side skirt is cracked, I saw some side skirts from a 2012 same color for sale locally, does any one know if they are interchangable, I think they are the same as the e92
05-08-2015, 10:48 PM | #2 |
YouTube.com/TvTara
6454
Rep 4,715
Yeah, I believe e92 and e93 2007-2012 are the same side skirts.
05-09-2015, 06:41 AM | #4 |
866
Rep 5,450
I am also sure that the part will fit, the body was not changed with the LCI cars, just the bumpers and some other cosmetic items, the side skirt does however have a different part number after 03/2010, so I am guessing maybe it has a slightly different design, but the mount points will be the same - you would just need to change both if they look a little different from the early ones. The M-Sport rockers do have the same part number from 2007 all the way until the end of life, so that indicates that everything will mount fine on yours and the part only changed part numbers due to a cosmetic difference.
2007 - 2010 01 PRIMED LEFT OUTER KICK PANEL 1 03/2010 51777173919 $128.36 01 PRIMED RIGHT DOOR SILL TRIM PANEL 1 03/2010 51777173920 $128.36 2010 and after 01 PRIMED LEFT OUTER KICK PANEL 1 03/2010 51777256105 01 PRIMED RIGHT DOOR SILL TRIM PANEL 1 03/2010 51777256106
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
