Hit the 1/8 mile today.
05-08-2015, 09:04 PM | #1 |
180
Rep 545
I wasn't planning on racing due to the oppressive heat (high 80's), but it cooled down a little and I headed out.
I was running full weight, 25 psi in the 555R's and launching in 1st on all runs at around 2K RPM's. No burnouts at all, but I did clean the tires off on the last run to make sure they were clean. Anyway, I was happy to be in the low 8's based on what I've read. Next time I'll try 2nd gear launches and see if it gets me into the 7's. My best 60' was a 1.88. Mods are BMS dual cone, Cobb Stage 2 Aggressive, catle$$ DP's, and drag radials. I did notice a slight hesitation between shifts that has me scratching my head. I datalogged each run, but I'm not able to view them properly yet. Could someone take a look at one of my datalogs from today and tell me how things are looking? Here's the file: https://www.dropbox.com/s/3blq07gynz...log18.csv?dl=0 Photos or it didn't happen, right?
- 335is DCT - 10.5 @ 132 and dropping!
05-08-2015, 09:54 PM | #3 | |
180
Rep 545
Thanks. Here you go: 16x8 from an e38 (I was told) ET23 5x120 Hub - 72.56 Tires: Nitto NT555R 245/50-16 Be warned: Required a decent amount of caliper grinding to fit the lightweight 16" setup. I might hit Beechbend tomorrow for some mid-low 12's.
05-08-2015, 10:43 PM | #4 |
32
Rep 269
I was wondering how you fit the 16" wheel on the rear.. Can you post pics of how much you grinded to make it fit? Thanks.
05-08-2015, 11:05 PM | #5 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
I pulled out some of my slips from last year and mid 7s with 1.8 60' on Toyo Proxies T1 Sports @ 20 psi. I think the bog is due to torque error with the OTS map. Shoot me an email and I'll help you fix that issue and see if we can't get you in the 6's with the DRs with a 1.6 60'. WedgePerformance@gmail.com
05-08-2015, 11:10 PM | #6 | |
180
Rep 545
05-08-2015, 11:13 PM | #7 |
149
Rep 3,552
try to find ethanol and use e30 map
best 1/8 is a 8.097@ 93.67 with a 2.033 60' on a little ethanol.
12.0 @ 117 |
05-09-2015, 12:29 AM | #8 |
1334
Rep 1,701
FMIC won't change much, maybe a bit of pressure drop. Shoot me an email. I have some information I'll need to get before we start.
05-09-2015, 11:18 PM | #10 | ||
180
Rep 545
PM Sent.
05-09-2015, 11:18 PM | #11 |
180
Rep 545
Thanks. I'd likely kill for your trap speed right now.
05-09-2015, 11:19 PM | #12 |
180
Rep 545
PM Sent and thanks!
05-09-2015, 11:20 PM | #13 |
180
Rep 545
Thanks. I should have the intercooler installed by noon tomorrow.
05-10-2015, 05:05 AM | #14 |
547
Rep 2,590
05-10-2015, 06:56 PM | #15 |
149
Rep 3,552
que?
stock turbos rwd. mods in sig.
12.0 @ 117 |
