05-08-2015, 01:42 PM | #1 |
11
Rep 90
Faulty Alloys
Is anyone having same problem as i am with alloys. My M sport wheels style 310M have started what appears to be chipping / furring on centre of alloy around wheel boss. Not a problem as my dealer has ordered replacement. problem being that was 16 weeks ago, and now have been informed it is at least another 3 weeks provisionally. Apparentley there is millions of pounds worth of replacements on order. Waited less time for delivery of my vehicle than repacement alloys.
05-10-2015, 12:33 AM | #5 |
183
Rep 1,259
I double checked my rims - no problem. On the other hand, I have two cars and garage - X4 is used for long trips.
Are there faults on the polished - and laquered- surface? |
05-10-2015, 06:44 AM | #6 |
11
Rep 90
have taken photo, just hoping better half can down load it for me. apparently it is a reaction between alloys and plastic wheel boss , so i have been told. both suppliers are supposed to be fighting it out where and with who the fault lies with.
05-11-2015, 12:40 AM | #8 |
183
Rep 1,259
Thanks for pictures - now I know what to look for.
There is a clear coat on the polished al. It looks as if the surface is "broken" and the al starts to corrode. This is common for polished rims with clear coat - but not after a couple of months. One possibel explanation is that the boss is too big,and will damage the clear coat when installed. Front wheels "worst" probably because of aggressive brake dust - don`t brake |
05-11-2015, 08:32 AM | #9 |
11
Rep 90
bosses have plenty clearance . so not that. might just be reaction between alloy and plastic boss as dealer said both suppliers are battling than one out. wont use brakes will try parachute to slow me down.
05-11-2015, 01:48 PM | #10 |
183
Rep 1,259
If bosses have plenty of clearence - what makes them stay? Probably a clip or spring - which could damage the clear coat when boss is installed.
I believe there have been some comic strips, where anchor have been used- more direct result! |
05-12-2015, 12:34 AM | #12 |
183
Rep 1,259
Chopper, thank you - very good pictures! One can see typical al-corrosion creeping under clear coat from edge of hole for boss.
To me it is obvious that clear coat is damaged at edge of hole for boss, probably when installing boss. First explanation: faulty installation of boss or "bad" boss. A second explanation could be "bad" clear coat - which can`t take the abuse when boss being installed. Whatever - it is BMW/supplier responsibility. Very probably BMW/supplier are working on the problem, but normally they will not tell customers, but solve the problem between them. Check your 310:s! |
05-12-2015, 05:30 AM | #13 |
430
Rep 2,527
It's not just for the 310 wheels. That corrosion has been reported on other styles as well, including the standard 18 inch fitments.
My dad has it on his winter sets, but not on the summer alloys. |
05-12-2015, 09:56 AM | #15 |
541
Rep 2,073
It seems to me that the clear coat doesn't have a hope of sticking properly to the sharp corners when the boss fits. The alloy should be rounded, instead it has two 45 degree corners....the clear coat will be thin there so damage will easily occur moisture is bound to get in.
Current: G01 M40i Silver / Tartufo
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D Last edited by clivem2; 05-13-2015 at 03:55 AM.. |
05-20-2015, 01:26 AM | #16 |
183
Rep 1,259
I belive that the boss and hole for it is according to STD procedures.
Very probably there is a problem in the process. Luckily I have no problem- after 7000 km. Early vehicle - before they had to ramp up due to high demand? |
06-01-2015, 12:55 AM | #17 |
183
Rep 1,259
Chopper, Big Geordie, any resolution to your problems? I still don`t have a problem, but I am worried, since 310:s are extremely costly. We only have two years of guarantee and no wheel-insurance in my neck of the woods.
I have noticed very limited interest/input when mechanical problems -vast interest when software issues. Do people have time to drive their X4:s? |
06-01-2015, 09:13 AM | #18 |
11
Rep 90
tjalle.
Waiting for a phone call today from dealer. new alloys due on thursday so he said. will let u know later in week. it,s only 20 weeks waiting so far. but seems BMW only interested in selling new cars, and not solving faults |
06-02-2015, 07:44 AM | #20 |
183
Rep 1,259
Big geordie, Chopper45, thanks. This supports my suspicion that supplier fucked up - it will cost him deerly. Since you are about to get new rims, they obviously has found the problem and rectified. Hopefully my rims were prior to "fuck up".
