The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Go through touchless wash and this happens!
      05-08-2015, 08:52 AM   #1
dhanni848
38
Drives: 06 330i
I have been through the touchless washes before, and even not that long ago. I have NEVER seen this happen.
      05-08-2015, 08:57 AM   #2
olivojoe
olivojoe's Avatar
93
Drives: 2011 335i xDrive
Is your windshield original?
I have seen this before when a windshield gets replaced and isn't sealed properly.
      05-08-2015, 08:57 AM   #3
bender rodriguez
149
Drives: Audi
That is not normal...
      05-08-2015, 09:04 AM   #4
dhanni848
38
Drives: 06 330i
It is original. I had the AC on and thought the soap smell was strong and the saw that.
I went through the same wash not a month ago!
Didn't have time to check to see if any seals are gone/moved.
      05-08-2015, 09:05 AM   #5
InControl
InControl's Avatar
59
Drives: '13 328i coupe
That sucks. Heavy rain used to over flow some rubber hosing under the hood close to the windshield and where the windshield meets the bottom seal and resulted with water inside my saab on a couple occasions. Will check my e92 if there's any weak spots, in the mean time run a bucket of water at the bottom half of the windshield and see what happens.
      05-08-2015, 09:08 AM   #6
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Your car pee ed itself
      05-08-2015, 09:17 AM   #7
dhanni848
38
Drives: 06 330i
I have seen and read about it happening but never had a car do it. Will check it all when I get home and
      05-08-2015, 09:21 AM   #8
atinybug
Drives: 07 e92 335i 6mt
There's these 2 little duct like things on either side of your car near the hood hinges that allow water to run through them to the ground. I'm betting they are full of leaves and stopped up.
      05-08-2015, 09:22 AM   #9
olivojoe
olivojoe's Avatar
93
Has anybody noticed this from a BMS Cowl Delete?
Not sure if the OP has it or not, but if you smelled the soap through the AC, maybe it found its way in through the exposed cabin filters.
      05-08-2015, 09:26 AM   #10
bender rodriguez
149
Drives: Audi
Yeah but a touch less wash does not use that much water. I would figure it would have to use a ton to flood up over to the cabin filter then into the ducts?
      05-08-2015, 09:46 AM   #11
thomas88162
19
Drives: E92 328i
Try your HVAC drains, like the one that your A/C drains from. Could be overflowing into the lowest (feet well) vents.
      05-08-2015, 09:47 AM   #12
dhanni848
38
Drives: 06 330i
I do not have a cowl delete. I think atinybug may have it. I will check this for sure. I think I cleared it out when I switched my cabin filter but possibly not, and that has been a little while.
      05-08-2015, 10:58 AM   #13
ajaye
31
Drives: 07 328xi SGM
If the rubber molding strip at the bottom of the windshield has degraded enough it may have lost contact with the bottom edge of the glass allowing water to sheet straight into the blower motor opening. The bottom of the windshield wiper cowl keys into the molding, so if that cowl has been off its also possible that it wasn't keyed back in properly, but you'd see that its not laying on the windshield right pretty easily...mine had this problem and the wiper arm grommets wouldn't line up either.
To re-seat the molding and the cowl, you have to remove the wiper arms from the pivot. I recommend having a second set of hands to help with the re install, keeping them positioned in the correct spot they are supposed to be when parked is a bitch.
I would also check to make sure none of these are missing.
http://www.realoem.com/bmw/enUS/show...diagId=51_5865
      05-09-2015, 12:01 PM   #14
dhanni848
38
Drives: 06 330i
It is the entire cowl price that has lifted. Where is a good place to buy this?
      05-09-2015, 12:10 PM   #15
335NJ
Drives: 2008 335i 6MT E90
Did you select "Interior carpet shampoo" at the menu?
      05-09-2015, 03:52 PM   #16
ajaye
31
http://www.realoem.com/bmw/enUS/show...diagId=51_5740
The lower molding (#5 above) has a large groove that fits around the bottom edge of the windshield glass. The windshield wiper cowl/cover (#13) has a lip on the bottom side that fits into a 2nd much narrower groove of the molding #5. When its fitted properly, the cowl will lay flat all the way across the windshield and be somewhat firm but its not what keeps the water out. I had to give the cover a few good smacks to seat it properly in a few spots, and could actually hear it kinda click into place. There were small centering marks on both pieces to help with aligning them left-to-right The connection between the cover, the molding and the windshield glass combined direct the water to the drains on either side at the corners of the hood instead of running down into the blower or onto the wiper motor. I would start with the molding first, its <$20 so even if everything is fine but just wasn't assembled properly, you won't feel bad about replacing it.
      05-09-2015, 08:43 PM   #17
dhanni848
38
Drives: 06 330i
The lower molding (#5 above) has a large groove that fits around the bottom edge of the windshield glass. The windshield wiper cowl/cover (#13) has a lip on the bottom side that fits into a 2nd much narrower groove of the molding #5. When its fitted properly, the cowl will lay flat all the way across the windshield and be somewhat firm but its not what keeps the water out. I had to give the cover a few good smacks to seat it properly in a few spots, and could actually hear it kinda click into place. There were small centering marks on both pieces to help with aligning them left-to-right The connection between the cover, the molding and the windshield glass combined direct the water to the drains on either side at the corners of the hood instead of running down into the blower or onto the wiper motor. I would start with the molding first, its &lt;$20 so even if everything is fine but just wasn't assembled properly, you won't feel bad about replacing it.
Awesome thanks!!!
