I'm Stumped- Oil level issues
05-07-2015, 07:15 AM | #1 |
13
Rep 72
Hey Guys,
Here's a quick rundown of the symptoms and what I've done on my 06 325: 1) Oil level was constantly at "low" even after pouring in 1Q of oil. 2) I replaced the oil sensor. When replacing the oil and oil sensor, I noticed that only 2Q of old oil came out of the engine. The oil was really thick and fouled up. The oil filter was also really fouled up. 3) After the oil and sensor repacement, the new sensor was giving the "ok" full level after the oil and sensor repacement. 4) Oil would gradually go down 1/4Q every week. I can see it going to after week 2: 3/4, then 1/2 after week 3, then 1/4 after week 4. 5) But here's the real mystery: 1 month later, the new sensor is doing the same thing as the old sensor and the level is stuck on "low" or 1/4 level immediately after adding 1Q. What do you guys think is going on? I have over 280K mi on car and do regular oil changes. I use OEM everything. The car is running strong otherwise. I don't notice any smoke or smell. Thanks for your help.
E46 S54: Black on Black, 6MT, Agency exhaust, ESS chip, KW2 coilovers, H&R Spacers. E93 N54: Black on Black, 6MT, FULLY STOCK. Sports PKG. E90 N52: Black, AT, H&R Sport springs, Hyper Silver 19" VMR V715 staggered Last edited by Tmaccus; 05-07-2015 at 07:33 AM.. Reason: spelling |
05-07-2015, 07:23 AM | #2 |
68
Rep 211
If the new sensor says the same thing as the old sensor, then I venture to think the sensor isnt broken. With that many miles, start looking for an oil leak. Sounds like its large enough to find it fairly easily.
If not, do a leakdown test on the cylinders and make sure the rings are sealing. You could also be leaking through worn valve guides and seals. Alternative option: after 280K, declare victory, get another one. Last edited by OP3NAIR; 05-07-2015 at 08:47 AM.. |
05-07-2015, 09:04 AM | #5 |
109
Rep 1,062
The oil sensors are known to not work correctly after you get to 180k, it's a software issue, not a sensor issue.
http://www.e90post.com/forums/showthread.php?t=926864 Best thing to do is empty out the oil, put in 7 quarts of new oil. Drive for 2-5 minutes to get the oil circulated, then drain & measure how much comes out. Should be pretty close to 7 quarts, if not exactly. Put in new oil, drive for 3000-5000-7000 miles or however much you think you can last without burning over a quart. Test and evaluate, you should now know at what rate your car burns oil. Driving styles & oil types will affect burn rate between oil change intervals (mobil1 is known to burn faster than BMW Castrol).
Sideways is the way of life.
05-07-2015, 09:08 AM | #6 |
181
Rep 1,681
But that's for the oil life, not oil level.
If OP only got 2 quarts out at the last oil change, seems the sensor is working if it says low oil. I'd say change the oil again and see how much comes out this time. If it's low again, that's not a sensor issue. |
05-07-2015, 11:44 AM | #8 |
142
Rep 726
I once had an issue with my sensor after replacing valve cover gasket and oil pan gasket. Then did an oil change...after driving for a couple of days it started reading low all the sudden, i got concerned and added 1qt to it but did nothing to the reading stayed as low. After i got home i drained the oil and it was overfilled by 1qt....meaning the sensor was failing. I refilled the engine with the 7qts and kept driving for a couple of days before i ordered a replacement sensor. ALL OF THE SUDDEN...the sensor worked again and read half full for a while then after driving even more, it read OK as full...ever since it has read fine...so it seems that it took time to adjust itself, im talking days... so i cancelled my previous order on the replacement sensor...just a thought.
2006 Bmw 325xi VMR V715/OE lip/Redlines/Zsp Springs
1999 Eclipse Spyder Gst 16g/264cams/550cc/255lph/corbeau seats/Comp Stage 4 Clutch/ECUflash etc... |
05-07-2015, 11:55 AM | #9 |
815
Rep 2,869
Check your valve cover, oil filter housing, and pan gasket for leaking...
Apparently there is an issue with the oil sensor after like 180,000 mile or something like that. There is a member on here that makes regular post about his high mileage e90 and his oil sensor problems. Apparently its a fault in the CPU, and even BMW could not "reset" it.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
05-07-2015, 12:13 PM | #11 |
13
Rep 72
OP here. There are no leaks. My driveway is clean as a whistle. I still can't believe the car survived on 2 quarts for an extended period of time.
05-07-2015, 02:24 PM | #12 |
163
Rep 468
Drives: Yes
When you rev the car, is there smoke coming out of the exhaust? If there is blue/gray smoke, that traditionally means that your engine is burning oil, which is typically (but not necessarily) caused by worn down piston rings, which would be VERY likely with such a high-mileage engine such as yours.
05-07-2015, 02:30 PM | #13 | |
13
Rep 72
E46 S54: Black on Black, 6MT, Agency exhaust, ESS chip, KW2 coilovers, H&R Spacers. E93 N54: Black on Black, 6MT, FULLY STOCK. Sports PKG. E90 N52: Black, AT, H&R Sport springs, Hyper Silver 19" VMR V715 staggered |
05-07-2015, 02:37 PM | #14 |
181
Rep 1,681
Nothing on the belly pan/splash shield? That usually keeps oil off the driveway, but I don't think it would hold 5 quarts either.
05-07-2015, 02:46 PM | #16 |
13
Rep 72
I got my starter replaced at the dealership about 8 months ago. Do you know if they would touch the components you're refering to?
05-07-2015, 02:55 PM | #17 |
107
Rep 485
It's attached to the manifold so it would have to come off with it to gain access to the starter. If the CCV is allowing oil to go into the intake and not return to the sump then you would burn off oil. You would have to pull the throttle body to see if there is any oil residue in the intake to know for sure. Normally it will return combustion vapors to the intake to be burnt and allow oil to drain back to the oil pan. There are several failure modes for this and excessive oil usage is one of them.
05-07-2015, 03:07 PM | #18 | |
13
Rep 72
05-07-2015, 03:16 PM | #19 |
107
Rep 485
The lack of a dipstick on these cars is annoying. I'm rebuilding an 06 325 that I bought at a salvage auction with front end damage. When I went to drain the oil about 13 quarts came out. I have no idea what the story was behind that. The oil pan and valve cover gasket leaked so I strongly suspect the CCV is bad so my weekend project is removing the intake. I have a feeling the previous owner was dumping oil in there to compensate for the leak and perhaps it was burning though the intake as well. So I'm replacing the CCV and hoses due to the other signs and also as PM since I'm rebuilding so much of the car anyway.
Tags |
oil burning problem sludge sensor |
