Valve cover gasket problem..
05-05-2015, 07:56 PM | #1 |
205
Rep 2,349
**UPDATE**
Fuel injectors seemed to be really dirty near the nozel, so i cleaned them as well. starting the RE assemble now. So my main problem - Car randomly starts to misfire (no actual code) random misfire making the car run rough between 2 and 3k rpm. Under hard acceleration car runs fine no problems. Oil was present on spark plugs, people suggested valve cover gasket.. Well today i got to my valve cover gasket.. only to find out Its in PERFECT condition ... im going to replace it anyways, but it looks almost brand new. So what now :/ So far only PRO of this whole situation, is a good chance to clean out all the crud from when i did my own walnut blasting.... OLD GaskET
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake Last edited by 335iNavyGuy; 05-05-2015 at 08:39 PM.. |
05-05-2015, 08:05 PM | #2 |
1646
Rep 4,877
I did a plug swap and found oil on one plug. Turned out I got "sloppy" on the last oil change, and plug #3 is where that oil wants to pool around (so gasket and plug are fine, just the oil runs into the hole when you pull the coil).
Might be the same deal with you? |
05-05-2015, 08:25 PM | #3 |
261
Rep 1,093
I didn't know you could tell its leaking by just looking at its condition. May look fine and not sealing perfectly (speculation). If you have oil on top of the spark plugs there's not many ways for it to get there.
05-05-2015, 08:40 PM | #4 |
205
Rep 2,349
Fair point, im putting the new one on as we speak, i also cleaned everything, fuel injectors, spark plugs, etc. Hopefully it just works.
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake |
05-06-2015, 07:11 AM | #5 |
Professional Monkey Trainer
65
Rep 423
You could also have a cracked valve cover. Happens a lot, causes oil leaks into spark plug holes. Something to watch out for.
JB4 G5 ISO / ER Charge Pipe and Tial BOV / Wagner FMIC / CYBA Tips & Air Scoops / AFE DCI / BMW PE Exhaust Mod / M3 Rep Bumper / Dynavin E9x
05-06-2015, 02:54 PM | #6 | |
205
Rep 2,349
And no i wont just use my eyes lol, ill use a DYE and black light to search out cracks. Good idea though thanks
07 E92
