Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > E90 LCI LED Taillight failure. Repairable? Cheap replacement?
      05-05-2015, 11:06 AM   #1
akasnow
Drives: 2009 Alpine White 335i E90
Exclamation E90 LCI LED Taillight failure. Repairable? Cheap replacement?
Hey guys, so I got a dreaded check bulb error randomly while driving and using blinker. I'll get a fast blink, and then sometimes it blinks fine with no error. Seems intermittent... but some LEDs on my RH Tail seem to be toast 100% of the time, whether I get an error out or not. '09 E90 LCI. Anyone dealt with this personally before? Reputable cheap replacement? Swap out boards on the back of unit possible? Thanks for the help!
TL;DR: 3 LEDs out on RH E90 LCI Tail. Other LED in cluster work part of the time. When I get bulb check error (usually while driving and turning on blinker after some bit of driving) then the other LEDs flash erraticly and are very dim.
Here you can see how it looks with no Error on dash:
[u2b]https://www.youtube.com/watch?v=FTw2zBHoqao[/u2b]
Here is how it looks when the Error is present on the dash:
[u2b]https://www.youtube.com/watch?v=pUxd-2gyPgQ[/u2b]
Last edited by akasnow; 05-05-2015 at 11:15 AM.. Reason: Youtube links wont embed properly?? Maybe it take a few mins?
      05-05-2015, 03:20 PM   #2
uber
uber driver
114
Drives: 2011 335i E90
look on rock auto. i bought a replacement for 60 bucks. works great.
      05-05-2015, 04:16 PM   #3
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
Are you sure it's not the cable that runs into the trunk lid?
Mine was bad and required repair. It had three broken wires.
I had the same issue on an e36 M3.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
Tags
failure, flicker, lci e90, led, tail light
