Best place to buy O2 sensors?
05-05-2015, 06:26 AM | #1 |
42
Rep 568
Who has the best prices on O2 sensors? I'm looking to replace all of mine.
AA Signature Exhaust / AA 3" Catless Downpipes / VRSF 7" FMIC / AFE Dual Cone Intake / ER Charge Pipe / Tial Q BOV / RPI Scoops / RB Upgraded PCV & Cap / BMS OCC / Alpina Trans Flash / Powered by JB4 G5 ISO
05-05-2015, 06:36 AM | #2 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
I would not replace them unless you get a fault code. I could sort of see it as preventative maintenance if you were say over 100k, but even then it's a stretch.
I have 110k on my N54, and they work just fine. I have ran a few checks on them earlier this year. You can get a Bosch parts app for free on android and iPhone. Use Bosch O2 sensors. They are OEM. I have read the O2 sensors are not real fun replacing on the n54 motor. Amazon should carry all 4 of them. eBay is another place to get them, but make sure you get them from a reputable dealer. You can save some money by going with universal Bosch sensors for down stream. They are typically around $50.00 each vs $90 to 100, but they are not plug and play; you will have to do the wiring. Probably gonna be spending about $300-400.00 for all 4 depending if you get the universal O2 sensors for the downstream or not. |
05-05-2015, 06:47 AM | #3 |
42
Rep 568
I got these 2 codes yesterday. (2C31 Lambda probe in front of catalytic converter, trimming control) and (2C77 Lambda probe behind catalytic converter, signal).. I think there may be more problems though because my car wouldn't build any boost and I also got a (30FF boost under target) code. I'm checking all connections and vacuum lines when I get off.
05-05-2015, 11:44 AM | #8 |
421
Rep 1,643
Bavauto had the best price I could find for Bosch 02 sensors. I'm at 114k and replacing only the fronts as preventive maintenance, plus I have some funky occasional stutters going on and my gas mileage has sucked for a while and am curious to see if it will help.
2007 E92 335i MT
05-05-2015, 11:47 AM | #9 |
1903
Rep 6,968
You have 2 before the catalytic converter and 2 after the catalytic converter. Typically you replace them in pairs. So, if the O2 sensor for banks 1-3 before the catalytic converter goes bad, then you should replace the O2 sensor for banks 4-6 before the catalytic converter too.
It sucks that you have one gone on each side of the converter. Now I know why you want to replace all 4. Yes, I would probably replace all 4 too. What year is your BMW? The part numbers are different for the N54 and N55 motors. I would think even for an N52 as well.. I can get all 4 on Amazon for around $260.00, but that's with getting 2 universals for the post cats. |
05-05-2015, 11:50 AM | #10 |
1903
Rep 6,968
I have a actron cp 9580a scanner. It can measure voltage of the O2 sensors. You can tell by the amount of voltage and frequency of such voltage (steady or jumpy) if one is bad.
05-05-2015, 11:39 PM | #13 |
BimmerPost Supporting Vendor
24263
Rep 190,950
We offer OE parts and price match any competitor
05-06-2015, 07:06 PM | #14 | |
1903
Rep 6,968
05-09-2015, 10:56 PM | #16 | |
1903
Rep 6,968
http://www.amazon.com/Bosch-15733-Ox.../dp/B000BZG8ZU" rel="" target="_blank">http://<a href="http://www.amazon.co...B000BZG8ZU</a> http://www.amazon.com/Bosch-17099-Ox.../dp/B000JZCYWI |
