Taking the tires off. Quick question
05-04-2015, 11:23 AM | #1 |
The Regime
32
Rep 225
Unless I'm missing it my car did not come with any tools to take off the wheel. What size tool do I need to take the nuts off? Need to install my lux angel eyes
05-04-2015, 11:30 AM | #2 | |
466
Rep 1,980
But to remove the wheels you will need a very low jack (or a ramp+jack) and a 17mm hex. The car comes with neither, because it doesn't have a spare. |
05-04-2015, 11:52 AM | #3 | ||
Master Bates
80
Rep 495
Definitely don't take off your nuts
CURRENT: 2020 G20 M340 xDrive — Carbahn Tune
RETIRED: 2011 E90 335i xDrive — Cobb AP3, PE Exhaust, Alpina TCU Flash, VRSF Charge Pipe 2017 Estoril Blue X1 M Sport — JB4 |
05-04-2015, 12:15 PM | #4 |
228
Rep 1,045
BMW wheels have no nuts...they use lug bolts, so you don't need to even think about keeping your nuts clean
Having a jack and a lug wrench are useful, even without a spare, as it is easier to insert a tire plug and then pump in air with a 12v compressor, so your RFT will not be ruined by using its RFT feature! |
05-04-2015, 12:42 PM | #6 |
291
Rep 2,189
Don't forget to break the initial torque on the bolts before you jack it up.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
05-05-2015, 05:38 AM | #8 | |
17317
Rep 18,739
Good advice here. But just to be clear, don't use the torque wrench to remove the wheel bolts (or your nuts - it might hurt). You use a torque wrench only for tightening fasteners to spec.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
05-05-2015, 07:57 PM | #9 |
14
Rep 59
Think about getting a wheel pin. It makes it much easier to mount the wheels. There are many wheel pin vendors. Here is one to check out.
http://burgertuning.com/wheel_hanger_pin_BMW.html |
