05-03-2015, 03:34 PM | #1 |
@obriennathaniel_f30 on Instagram
515
Rep 1,062
Drives: 582whp/596wtq '13 335i
Eurocharged Houston Flash tune dyno
this is not a finalized tune, it's still being fine tuned etc, next will be the Pure Stage 2 😎
This is on 93 pump gas, no meth, and all the bolt ons in my sig.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
05-03-2015, 06:31 PM | #2 |
Pace Car Driver
1557
Rep 3,166
Amazing numbers for the mods you have. Must pull like a freight train.
As these get more popular, I'll have to reconsider and possibly pass on the JB4 or even a Stage 1. |
05-03-2015, 06:52 PM | #5 |
124
Rep 264
05-03-2015, 10:00 PM | #8 | |
515
Rep 1,062
Meth isn't being used on this dyno Lol oh, ok Stock boost varies with the climate/altitude. The car targets a certain power level, not a boost level, so with the change in outside temperature air/altitude etc the boost will change.
05-03-2015, 10:02 PM | #9 |
515
Rep 1,062
What do you mean? They can tune for that. They're doing this tune to see what the car can do with the stock turbo, then they're going to install the Pure Stage 2 and tune for it.
05-04-2015, 12:41 AM | #10 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Two thoughts. Torque curve looks strange compared to the power output + 450ftlbs @ 2.75rpm?
345whp seems low for 17.75 boost. Are you running logs? Be interesting to see the advance curve for any timing pulls.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
05-04-2015, 01:13 AM | #11 | |
1787
Rep 4,528
At max HP RPM range ie circa 5.5k RPM, boost is much lower ie <13psi. Assume timing and or AFR are governing boost profile. |
05-04-2015, 01:27 AM | #12 | ||
677
Rep 1,349
Drives: BMW F80 M3
But i was thinking the same as you. Max boost at low rpm. Drops off from there. Just the same what i experienced trying to have mine flashed. Stage2 flash only tune on F series will not bring you much. I bet you some belgian beer for it that you wont get over 400whp flash only. |
05-04-2015, 02:45 AM | #13 |
210
Rep 1,252
i mean my local dealer said he can't bench flash and he needs to send it to eurocharged HQ.
Docrace 6266
05-04-2015, 03:10 AM | #14 | |||
515
Rep 1,062
05-04-2015, 07:55 AM | #15 | |
90
Rep 648
05-04-2015, 08:32 AM | #16 | ||
677
Rep 1,349
Drives: BMW F80 M3
05-04-2015, 08:33 AM | #17 | ||||
677
Rep 1,349
Drives: BMW F80 M3
05-04-2015, 10:13 AM | #18 |
3131
Rep 5,264
Still skeptical of that much torque but if it is front loaded you will have a major problem launching the car if you are drag racing with it.
Most of us with tunes dropped the boost (limited max PSI) in 1st & 2nd gears. Personally with a 7DCT I started in 2nd at the drag strip because 1st was too strong for the tires. My boost in upper mid range was a bit over 18psi in a N54 without timing pulls on 100 octane fuel. FWIW all Terry's record runs were second gear starts. Sample of trying to run 93 on the 100 map. Could run the 100 map with a 93/100 mix. Purple line is ignition advance, you can see the major pull, attempted recovery then another pull. Wish I had saved more of my pictures, logs etc from the 335is but I needed the space when I started to build the Cobra & the 435 was not going to be modified.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 05-04-2015 at 10:22 AM.. |
05-04-2015, 11:52 AM | #19 |
94
Rep 425
This is awesome, Nathaniel! Congrats!
It sure does help having that huge 3.5" DR-1 to VS-1 mandrel connection. We want to see some record breaking numbers soon! |
05-08-2015, 06:36 AM | #20 | |||
515
Rep 1,062
Haha hell yea it does!!! I'll do my best! Them and they're customers have all said they LOVE the exhaust so thumbs up to yall!
05-08-2015, 09:46 AM | #21 |
181
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
Interested for more info on the flash. I have a '14 335i so would there be different performance on mine due to the larger DP flange and electronic WG? I didn't even know flashing the ECU was available already I still thought they were locked up so this is great news. I too have a local eurocharged dealer so can't wait to hear more info!
05-08-2015, 12:38 PM | #22 |
651
Rep 4,323
Why not do the Pure2 first and then tune?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
