Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Flat spot in powerband
      05-03-2015, 09:54 AM   #1
M3_Mad
Petrol Head
M3_Mad's Avatar
United Kingdom
Drives: 2006 BMW 320si
2006 BMW 320si  [0.00]
Hi all,
Bit of a strange one although might be an easy diagnosis for some of the gurus on here. Was coming off the slip road onto a motorway today giving it some welly and noticed a small flat spot in the powerband between 2.5k-3k. Very momentary and disappeared almost as soon as it had appeared, but have tried similar acceleration under full load after and noticed it once or twice again. Doesn't happen every time either.
MAF? Plugs? Engine only has 31k on it and plugs were changed at 29k.
Thanks,
MG
"Any customer can have a car painted any colour that he wants, so long as it is black" - Henry Ford
      05-03-2015, 10:16 AM   #2
Douche
466
Drives: Car
CDV
      05-03-2015, 12:08 PM   #3
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Originally Posted by Douche View Post
CDV
As the OP wasn't complaining about driveline slip, what does the CDV have to do with a power band flat spot?
Tom
      05-03-2015, 12:15 PM   #4
Douche
466
Drives: Car
CDV
Tom
I don't know, symptoms like this reek of fuel supply issues, but I commented that the injectors might be leaking in another thread and got shut down in favour of a "more likely" CDV fault, and that some cars don't have injectors...
Since I don't know if his car has injectors (!!) and that CDV is a more likely issue that causes these symptoms (!!!!!!), I said CDV.
      05-03-2015, 12:26 PM   #5
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
Do you have an N55? I have noticed this as we'll, particularly in 2nd gear. It flattens for maybe a half second or so, then it's fine. I don't really notice it in any other gears.
      05-03-2015, 12:54 PM   #6
M3_Mad
Petrol Head
M3_Mad's Avatar
United Kingdom
It's an N45B20S. Bit of a fragile engine, was hand built by Sauber in England so quite difficult to find out literally anything about it. Took BMW UK 2 weeks to confirm the correct type of oil that should be used in this engine.
To everyone else, I don't think it is the CDV, problem has occurred when I've been in gear not immediately after changing.
If it's injectors do you think I'll get away with sticking some Redex in a couple tanks of fuel?
Thanks again lads.
      05-03-2015, 12:59 PM   #7
Welcome to NBA Jam
Is it the shoes!?
3884
Cleaning the injectors wouldn't be a bad thing to do at all. If you want to get really thorough, you can take out your injectors to get them cleaned with a ultrasonic injector cleaner (it basically vibrates hem really really fast). But you'll be out of a car for the duration of the cleaning, depending on if you need to ship them somewhere.
      05-03-2015, 01:38 PM   #8
M3_Mad
Petrol Head
M3_Mad's Avatar
United Kingdom
Considering using Terraclean if it might be an injector problem. Anyone has experience of this service?
http://www.haynesvehicleservices.co....es/terraclean/
