Manual transmission fluid is 75w-90. Same as diff?
05-01-2015, 01:52 PM | #2 |
1007
Rep 2,108
The oil type (BMW designation) should be written on a sticker on the side of manual transmission, if it still hanging in there.
Mine, an early XI, had MFT-LT-2 from factory, 75W80 GL4 http://www.ecstuning.com/BMW-E90-325...3.0L/ES197386/ Used this one during replacement, I suspect it is same thing as the OEM LT-2, but not 100% positive. Shifted the same after replacement, around 60K: http://www.ecstuning.com/BMW-E90-325....0L/ES1893847/ |
05-01-2015, 01:59 PM | #3 | |
149
Rep 1,995
05-02-2015, 02:30 PM | #4 |
1007
Rep 2,108
Redline has an application guide which you can find what they recommend:
http://www.redlineoil.com/application.aspx They recommend automatic transmission fluid for my car, you can check yours. It doesn't seem as simple as the viscosity ratings. |
05-04-2015, 03:14 AM | #6 | |
1007
Rep 2,108
Not much knowledgeable but I hear some manual transmissions having brass synchros are not compatible with all gear oil, even though it is same spec. Also differential oil probably has different friction elements than manual transmission oils. Differentials don't have synchros to worry about. |
