KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-05-2008, 11:35 AM | #1 |
17
Rep 532
BBS RS-GT (8.5/9.5) from e46 M3 - What spacers?
Hello all,
I was told that I would need to run spacers up front, and I'm a total idiot when it comes to understanding offset. My philosophy has always been to order them to fit rather than retrofit. However, I'll be transferring my 19" RS-GTs to the e92 M3 after I get the lips refinished. What spacer size would be recommended to run these comfortably? Thanks! Patrick |
02-06-2008, 06:46 PM | #2 |
2037
Rep 25,989
I'm assuming your front wheels are +35 offset and your rear wheels are +25. If this is the case, your front wheels should fit, but to ensure the most flush fit, you can add a 5-10mm spacer to the front depending how "flush" you want to your wheels to look. A 245/35/19 and 265/35/19 can be safely run with your wheels on the E92 M3.
02-06-2008, 06:49 PM | #3 |
125
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
VMR,
If he runs a spacer does he need longer lug nuts/bolts?
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
02-08-2008, 05:22 PM | #4 |
2037
Rep 25,989
Yes, most spacers that are 10-15mm in width should come with longer lug bolts, however if they don't you must find longer lug bolts before installing the spacers. Quality companies like H&R always include longer lug bolts to compliment their spacers.
03-27-2008, 08:59 PM | #6 |
148
Rep 2,278
I have 8.5x19 et 35 and 9.5x19 et 40 bbs rs-gts on my e90 with 10 mm H&R spacers on the rear wheels. I hope to use these light wheels on my M3 with a 15mm spacer on the rear, and either a 5mm spacer on the front. The red centercaps should look nice with my Fox red seats.
2015 f80 M3, 2016 GT3
